查看: 1652|回复: 7
[维修经验]
RESET Dell Bioses
发表于 2016-9-10 16:20:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
Dell bios password removal for latest models
RESET Dell  Bioses
Reset Dell 15R-N5110 Bios
Addcaption
  • remove motherboard from you laptop.
  • connect power and turn on.
  • short G2201 only one time.its shout down.
  • remove power and assemble your laptop again
  • Then go to bios by press F2.
note: This instructions for helponly and for professionals only. general users do not try this.
      Don't short G2201 two times or in even count.it will show youpassword prompt again.
RESET DELL 1545 Bios
1545mobo  with Graphics
1545without Graphics
1.     removemotherboard from you laptop.
2.     connectpower and turn on.
3.     shortG49 only one time.its shout down.
4.     removepower and assemble your laptop again
5.     Thengo to bios by press F2.
         1545 without graphics canbe reset only to remove wifi cover.
      Don't short G49 two times or in even count.it will show you passwordprompt again.
发表于 2016-9-13 14:11:27 | 只看该作者 �
Welcome to join our xunwei!
发表于 2016-9-13 11:00:29 | 只看该作者 �
我給他翻译下!
Addcaption   附言
remove motherboard from you laptop.                    啪啪几下 拆机 取下主板
connect power and turn on.               接电源 按开关点火
short G2201 only one time.its shout down.   短接主板 G2201跳线点 仅仅一次,机器关机鸟
remove power and assemble your laptop again   拔掉电源 然后啪啪几下螺丝装好主板复原
Then go to bios by press F2.      F2进入CMOS 设置
note: This instructions for helponly and for professionals only. general users do not try this.    注意哦:这个是对于专业人士才搞的哈,个人别闲的蛋疼搞这个。
      Don't short G2201 two times or in even count.it will show youpassword prompt again.  别短接 G2201跳线点一次超过2次以上,这样搞他会重新提示你的密码咯!
1545without Graphics     1545 集显没独显卡的货
1.     removemotherboard from you laptop.     啪啪拆机取出主板
2.     connectpower and turn on.     接电源 点火开机
3.     shortG49 only one time.its shout down.   短接 G49跳线点一次,然后关机
4.     removepower and assemble your laptop again    取下电源 啪啪几下装回去
5.     Thengo to bios by press F2.    F2进入 CMOS
note: This instructions for helponly and for professionals only. general users do not try this.   注意:专业人士才搞。个人不要乱搞
         1545 without graphics canbe reset only to remove wifi cover.   1545这货没独显 只要打开WIFI 的盖子短接跳线点就可以搞定了,
      Don't short G49 two times or in even count.it will show you passwordprompt again.  搞短接G49达2次以上,他会重新要输入密码
发表于 2016-9-13 09:09:04 | 只看该作者 �
这是个什么鬼
H55
我已经给他翻译。。。。。。。。。。。。 看下面  详情 回复 发表于 2016-9-13 11:00
发表于 2016-9-13 11:00:55 | 只看该作者 �
发表于 2016-9-13 12:03:34 | 只看该作者 �
翻译也是不懂啊
!!!只知道是清密码。
H55
那就 老火了。。。。。  详情 回复 发表于 2016-9-13 13:07
发表于 2016-9-13 13:07:45 | 只看该作者 �
乐童淘 发表于 2016-9-13 12:03
翻译也是不懂啊
!!!只知道是清密码。
那就 老火了。。。。。
再认真看了一次,那像懂了,两款机,有跳线点短后清密码。  详情 回复 发表于 2016-9-13 15:40
发表于 2016-9-13 15:40:53 | 只看该作者 �
H55 发表于 2016-9-13 13:07
那就 老火了。。。。。
