查看: 2864|回复: 2
[显卡维修]
七彩虹 8500GT MATS测试结果
发表于 2012-4-22 22:35:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 山东济南 来自 山东济南
   LANE    EB0 READ ERR EB0 WRT ERR  EB1 READ ERR EB1 WRT ERR  UNKNOWN ERR
FBD[ 31:  0]      2018460     71648763      2015685     71630641            0
FBD[ 63: 32]      7276544     68769022      7260412     68763885            0
External Bank 0 Failing bits:
     0   1   2   3   4   5   6   7   8   9  10  11  12  13  14  15
    16  17  18  19  20  21  22  23  24  25  26  27  28  29  30  31
    32  33  34  35  36  37  38  39  40  41  42  43  44  45  46  47
    48  49  50  51  52  53  54  55  56  57  58  59  60  61  62  63
External Bank 1 Failing bits:
Read    Error Count: 18571101
Write   Error Count: 280812311
Unknown Error Count: 0
BIT  FRONT WRITE  FRONT READ  BACK WRITE  BACK READ    UNKNOWN
  0    43297859     1444368    43287052     1442885           0
  1    58183450     1205804    58177509     1202555           0
  2    43519749     1552633    43509906     1550131           0
  3    58530777     1292645    58523495     1290458           0
  4    43236408     1427798    43235335     1423107           0
  5    58520377     1207939    58517224     1204071           0
  6    43340280     1437955    43337191     1431671           0
  7    58466584     1328454    58465926     1326883           0
  8    35434947     1413981    35427017     1410274           0
  9    56190727     1259504    56187711     1256313           0
10    35307404     1235078    35300579     1231035           0
11    55971599     1224797    55967784     1221108           0
12    35663197     1236084    35663045     1233576           0
13    56410279     1375090    56408910     1373591           0
14    35984175     1565641    35981283     1563815           0
15    56334558     1435349    56332636     1432768           0
16    29767657      842315    29758976      839545           0
17    52697493      891043    52693062      887834           0
18    29768242      842457    29759707      839684           0
19    52696184      890929    52692142      887678           0
20    29710585      842082    29709504      839202           0
21    52715165      891413    52714399      888089           0
22    29709532      842090    29708570      839345           0
23    52712176      890949    52711981      887692           0
24    29765748      841698    29756495      838861           0
25    52705343      891669    52700648      888309           0
26    29766338      841844    29757057      838998           0
27    52704079      891562    52699768      888153           0
28    29709314      841476    29708579      838564           0
29    52715868      891822    52715597      888358           0
30    29708327      841319    29707706      838495           0
31    52713155      891407    52713274      887991           0
32    39485754     3863890    39495025     3853757           0
33    49426244     5821550    49441236     5808861           0
34    39325871     3780897    39336440     3771025           0
35    50343233     5848287    50356928     5834749           0
36    42280406     3753163    42283601     3747710           0
37    48394331     5793156    48396085     5781064           0
38    41928562     3667645    41926040     3658325           0
39    47771502     5537251    47771325     5527915           0
40    32185213     3974731    32193176     3964413           0
41    45557397     5618008    45562507     5605803           0
42    31966237     3881885    31976171     3872438           0
43    45647586     5891219    45651831     5876816           0
44    33807679     4029111    33812662     4022178           0
45    44318698     5551094    44322955     5540417           0
46    34063151     4177063    34062906     4167683           0
我用的 7 测得  我感觉测得不对吧 显存有 好多个呢 大家看看哪个问题 是不是GPU坏了哦
发表于 2012-4-22 22:35:41 | 只看该作者 来自: 山东济南 来自 山东济南
本文来自:迅维网(www.chinafix.com.cn),出处:http://www.chinafix.com.cn/forum ... d=526976&extra=
检测结果肯定不对。  发表于 2012-4-22 22:58
发表于 2012-4-23 09:12:11 | 只看该作者 来自: 河南洛阳 来自 河南洛阳
换8和9都试试。然后写下bios再测。不行把GPU加焊
