查看: 11747|回复: 11
三极管NPN和PNP判断方法
 关闭 [复制链接]
发表于 2006-10-30 09:59:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 广西南宁 来自 广西南宁
<p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">三极管</span><span lang="EN-US"><font face="Times New Roman">NPN</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">和</span><span lang="EN-US"><font face="Times New Roman">NP</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">判断方法</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt 36pt; TEXT-INDENT: -36pt; mso-list: l65 level1 lfo1; tab-stops: list 36.0pt;"><span lang="EN-US" style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">(1)<span style="FONT: 7pt 'Times New Roman';">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">三极管的极性判断及管型判断</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span lang="EN-US"><span style="mso-spacerun: yes;"><font face="Times New Roman">&nbsp;&nbsp;&nbsp; </font></span></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">把数字万用表打到二极管档,首先用红表笔假定三极某一只引脚为</span><span lang="EN-US"><font face="Times New Roman">b</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">极,再用黑表笔分别触碰三极管其余两只引脚,如果测得有两次结果读数相差不大,并且在</span><span lang="EN-US"><font face="Times New Roman">600</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">左右,则表明我们的假定是对的,红表笔接的就是</span><span lang="EN-US"><font face="Times New Roman">b</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">极,而且此管为</span><span lang="EN-US"><font face="Times New Roman">NPN</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">型管(参照下图),</span><span lang="EN-US"><font face="Times New Roman">c</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">、</span><span lang="EN-US"><font face="Times New Roman">e</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">极的判断,在两次测量中,以测得读数较小的一次为例,黑表笔接的是</span><span lang="EN-US"><font face="Times New Roman">c</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">极,读数较大的一次黑表笔接的</span><span lang="EN-US"><font face="Times New Roman">e</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">极。</span></p><p class="MsoNormal" align="center" style="MARGIN: 0cm 0cm 0pt; TEXT-ALIGN: center;"><span lang="EN-US"><shapetype id="_x0000_t75" stroked="f" filled="f" path="m@4@5l@4@11@9@11@9@5xe" opreferrelative="t" ospt="75" coordsize="21600,21600"><stroke joinstyle="miter"></stroke><formulas><f eqn="if lineDrawn pixelLineWidth 0"></f><f eqn="sum @0 1 0"></f><f eqn="sum 0 0 @1"></f><f eqn="prod @2 1 2"></f><f eqn="prod @3 21600 pixelWidth"></f><f eqn="prod @3 21600 pixelHeight"></f><f eqn="sum @0 0 1"></f><f eqn="prod @6 1 2"></f><f eqn="prod @7 21600 pixelWidth"></f><f eqn="sum @8 21600 0"></f><f eqn="prod @7 21600 pixelHeight"></f><f eqn="sum @10 21600 0"></f></formulas><path oconnecttype="rect" gradientshapeok="t" oextrusionok="f"></path><lock aspectratio="t" vext="edit"></lock></shapetype></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span lang="EN-US"><font face="Times New Roman"></font></span>&nbsp;<img src="attachments/dvbbs/2006-10/200610301591210613.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2006-10/200610301591210613.jpg\');}" onmousewheel="return imgzoom(this);" alt="" /></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span lang="EN-US"><font face="Times New Roman">NP</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">型管的判断只须把表笔调换即可,测量方法同上。</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt 36pt; TEXT-INDENT: -36pt; mso-list: l65 level1 lfo1; tab-stops: list 36.0pt;"><span lang="EN-US" style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">(2)<span style="FONT: 7pt 'Times New Roman';">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">三极管的好坏判断</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21.75pt;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">把数字万用表打到二极管档,</span><span lang="EN-US"><font face="Times New Roman">bc</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">、</span><span lang="EN-US"><font face="Times New Roman">be</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">极正向读数在</span><span lang="EN-US"><font face="Times New Roman">600</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">左右,反向为∞(</span><span lang="EN-US"><font face="Times New Roman">e</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">极正向反向均为∞为好管,反之为坏管)。</span></p><br/>
发表于 2006-10-31 08:26:39 | 只看该作者 来自: 广西南宁 来自 广西南宁
IRF 630 是三极管吗?
发表于 2006-11-2 06:44:42 | 只看该作者 来自: 四川成都 来自 四川成都
场管吧?我测是这样用表笔先把三脚短路一下,再把有字的面向着自己黑表笔接最右边的脚用红表笔去测另两只脚,先测中间阻值应该是无穷大,再测最左边的,阻值无穷大,再回过来测中间那只脚就会有阻值在600左右
发表于 2006-11-2 07:24:22 | 只看该作者 来自: 广西南宁 来自 广西南宁
<p>呵,这个要分清楚的</p>
发表于 2007-3-14 19:48:12 | 只看该作者 来自: 新疆昌吉 来自 新疆昌吉
大哥,看不到图呀?
麻烦给传一份,
E---MAIL:GE6500@126.COM
发表于 2007-3-17 11:25:26 | 只看该作者 来自: 湖北襄阳 来自 湖北襄阳
谢谢非常好 顶
发表于 2007-3-18 18:47:37 | 只看该作者 来自: 广东深圳 来自 广东深圳
谢谢非常好 顶!!!!!!!!!!!!!!!
发表于 2007-3-19 12:53:50 | 只看该作者 来自: 贵州贵阳 来自 贵州贵阳
已经收下,感谢楼主分享!!!可惜没有图片
发表于 2007-5-29 15:14:42 | 只看该作者 来自: 辽宁抚顺 来自 辽宁抚顺
判断不了啊!
判断不了啊!
发表于 2007-5-29 18:17:01 | 只看该作者 来自: 北京海淀 来自 北京海淀
学习中, 确实不错,,就是看不到图
发表于 2007-5-29 20:19:36 | 只看该作者 来自: 江西赣州 来自 江西赣州
好,谢谢拉~~~~~~~~
发表于 2007-5-31 17:21:09 | 只看该作者 来自: 辽宁抚顺 来自 辽宁抚顺
看不到图啊啊!!!!!
