查看: 2260|回复: 0
[显卡维修]
X1950XTX R5检测出错情高手看看,谢谢!
发表于 2012-10-19 09:44:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
显卡出错是逆时针第2颗吧?故障严重吗?
R5MEMID version 1.03, (c) Copyright ATI Technologies Inc, 2006
Log file generation enabled to .\R5MEMID.LOG ...
Extended logging enabled ...
Reference data file (RDF) loading disabled ...
  [1] Mem production test FB001
    Failing Bits
      rk0 chB: 0
  [2] Mem production test FB063
    Failing Bits
      rk0 chB: 0
  [3] Mem production test FB064
    Failing Bits
      rk0 chB: 0
  [4] Mem production test FB065
    Failing Bits
      rk0 chB: 16
  [5] Mem production test FB066
    Failing Bits
      rk0 chB: 0
  [6] Modified FB088
    Failing Bits
      rk0 chB: 0
  [7] Modified FB091
    Failing Bits
      rk0 chB: 0
[1  ] Mem production test FB001                           : FAIL
    Error ID G0FB096
  1024 x  768 - argb8888 (60 Hz): TEST FAILURE
    Error count: total[16744448] chB[16744448]
[2  ] Mem production test FB063                           : FAIL
    Error ID G0FB096
    Error count: total[141824] chB[141824]
[3  ] Mem production test FB064                           : FAIL
    Error ID G0FB096
[4  ] Mem production test FB065                           : FAIL
    Error ID G0FB096
    Error count: total[523264] chB[523264]
[5  ] Mem production test FB066                           : FAIL
    Error ID G0FB096
    Error count: total[539392] chB[539392]
[6  ] Modified FB088                                      : FAIL
    Error ID G0FB088
    Error count: total[3072] chB[3072]
[7  ] Modified FB091                                      : FAIL
    Error ID G0FB091
TEST RESULT SUMMARY:
R580/M59 (0x7240) detected.
512M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
    Error ID G0FB096
    Error ID G0FB096
    Error ID G0FB096
    Error ID G0FB096
    Error ID G0FB096
    Error ID G0FB088
    Error ID G0FB091
Failure detected.
