ZXCVWtest
查看: 1108|回复: 0
[内存维修]
十万火急!!!!
发表于 2008-7-8 15:45:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
有哪位手上有以下要求的内存条的PCB GERBER啊,请发给我.谢谢!!
Memory capacity - 4GB
Memory type - DDR2
Clock speed- 667 MHz
Date width: ECC registered
Chips- FBGA
Single chip capacity- 512X4 Mb
No of chips 18
No of BGA ball in a chip - 63 ball
chip dimension - 9 X11.5
RAM PCB " 4GB DDR2 667 ECC Reg 2Rx4 solution using the (DDP512x4), 18 chips.
Available chip is  512x4, 63 balls, 9x11 .5mm "
三星颗粒, 外围尺寸 5250*720 MIL.  谢谢啦!
Email: kevenspcb@gmail.com
