查看: 1883|回复: 1
[显卡维修]
急救120,请高手看一下MATS结果
发表于 2008-3-16 19:01:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
GF4 mx440  MATS测试结果
Errors found.  Use .Status() or .PrintErrors() for more info.
This message will only appear once.
   LANE    EB0 READ ERR EB0 WRT ERR  UNKNOWN ERR
FBD[ 31:  0]            0     12742906            0
FBD[ 63: 32]            6          537            0
FBD[ 95: 64]            0            0            0
FBD[127: 96]            0            0            0
External Bank 0 Failing bits:
     0   1   2   3   4   5   6   7   8   9  10  11  12  13  14  15
    33  34  38
Read    Error Count: 6
Write   Error Count: 12743443
Unknown Error Count: 0
BIT  FRONT WRITE  FRONT READ  UNKNOWN
  0     3900251           0           0
  0     2172580           0           0
  1     6311539           0           0
  1     4455642           0           0
  2     4075592           0           0
  2     4134538           0           0
  3     5844768           0           0
  3     2121403           0           0
  4     3916457           0           0
  4     2163496           0           0
  5     6203057           0           0
  5     4444556           0           0
  6     3969820           0           0
  6     2186453           0           0
  7     6183098           0           0
  7     4445015           0           0
  8     4077053           0           0
  8     2374011           0           0
  9     5871390           0           0
  9     2130437           0           0
10     3958376           0           0
10     2175801           0           0
11     5871623           0           0
11     2158744           0           0
12     4074347           0           0
12     4031303           0           0
13     6246319           0           0
13     4373764           0           0
14     3917677           0           0
14     2178450           0           0
15     6320783           0           0
15     4455400           0           0
33         530           6           0
34          10           0           0
38           6           0           0
发表于 2008-3-16 19:06:55 | 只看该作者 �
补充一下
补充一下,我的64m显卡出现大量竖条,请高手把脉!
