查看: 2698|回复: 3
[显卡维修]
帮忙看下1950GT 的R5MEMID1的测试结果
发表于 2011-2-10 18:00:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
我倒第一次用R5检测显卡 可是怎么都看不懂 郁闷。。。。。。请问哪里是报错的脚位显示啊。
R5MEMID version 1.03, (c) Copyright ATI Technologies Inc, 2006
Log file generation enabled to .\R5MEMID.LOG ...
Extended logging enabled ...
Reference data file (RDF) loading disabled ...
  [1] Mem production test FB001
    Failing Bits
      rk0 chA: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
      rk0 chB: 0 1 14 31
      rk0 chE: 4 6 7 8 9 10 11 13 14 16 17 18 19 20 21 22 23 24 26 27 28 29 30 31
      rk0 chF: 6 13
      rk0 chG: 2 4 5 6 9 10 11 14 16 17 18 27 28 30 31
      rk0 chH: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  [2] Mem production test FB063
    Failing Bits
      rk0 chA: 1 2 3 4 6 7 8 9 10 11 12 13 14 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
      rk0 chB: 0 31
      rk0 chE: 7 19 20 30 31
      rk0 chG: 9 30
  [3] Mem production test FB064
    Failing Bits
      rk0 chA: 0 1 2 3 6 7 8 9 10 11 12 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
      rk0 chB: 0 1
      rk0 chE: 7 19 20 31
      rk0 chG: 8 9 30
  [4] Mem production test FB065
    Failing Bits
      rk0 chA: 0 1 2 3 4 6 7 8 9 10 11 12 13 14 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
      rk0 chB: 0 31
      rk0 chE: 3 7 11 12 19 20 30 31
      rk0 chG: 9 18 25 30
  [5] Mem production test FB066
    Failing Bits
      rk0 chA: 1 2 3 5 6 7 8 9 10 11 12 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
      rk0 chB: 0 31
      rk0 chE: 3 7 12 19 20 31
      rk0 chG: 8 9 18 30
  [6] Modified FB088
    Failing Bits
      rk0 chB: 0
      rk0 chE: 7 9 11 14 16 20 26 30 31
      rk0 chF: 22
      rk0 chC: 21
      rk0 chG: 16 25
  [7] Modified FB091
    Failing Bits
      rk0 chB: 0
      rk0 chE: 7 9 11 14 16 19 20 26 30 31
      rk0 chF: 22
      rk0 chC: 20
      rk0 chG: 4 8 9 16 18
TEST RESULT SUMMARY:
RV570/M68 (0x7288) detected.
256M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Mem production test FB001                           : FAIL
    Error ID G0FB096
  1024 x  768 - argb8888 (60 Hz): TEST FAILURE
    Error count: total[16726849] chA[14785] chB[5] chE[249] chF[3] chG[127] chH[16711680]
[2  ] Mem production test FB063                           : FAIL
    Error ID G0FB096
    Error count: total[1048209] chA[1652] chB[3] chE[16] chG[10] chH[1046528]
[3  ] Mem production test FB064                           : FAIL
    Error ID G0FB096
    Error count: total[1047957] chA[1398] chB[3] chE[15] chG[13] chH[1046528]
[4  ] Mem production test FB065                           : FAIL
    Error ID G0FB096
    Error count: total[2096231] chA[3106] chB[8] chE[31] chG[30] chH[2093056]
[5  ] Mem production test FB066                           : FAIL
    Error ID G0FB096
    Error count: total[2096412] chA[3294] chB[4] chE[35] chG[23] chH[2093056]
[6  ] Modified FB088                                      : FAIL
    Error ID G0FB088
    Error count: total[113148] chA[14826] chB[1] chE[13] chF[1] chC[1] chG[2] chH[98304]
[7  ] Modified FB091                                      : FAIL
    Error ID G0FB091
    Error count: total[113410] chA[15080] chB[1] chE[18] chF[1] chC[1] chG[5] chH[98304]
Failure detected.
公版    正8个颗粒。
发表于 2011-2-11 15:57:47 | 只看该作者 �
回复 自由如风 的帖子
通常那麼多錯誤點,我會先加焊GPU
发表于 2011-2-11 23:12:38 | 只看该作者 �
我修过蓝宝的x1950排列这个样子的
H G F E
             D
             C
             B
             A
发表于 2011-2-12 12:10:22 | 只看该作者 �
先 修 A 通道
