标题: 9550花屏 [打印本页]
作者: 马任知    时间: 2010-6-23 22:50
标题: 9550花屏
9550 128M 128BIT花屏,是哪个显存芯片坏了.
R3测结果:
R3MEMID version 1.07, (c) Copyright ATI Technologies Inc, 2003
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
TEST RESULT SUMMARY:
Rv350 (0x4153) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID 0VB001
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDA0 8 MDB0 24 25 26 28 29 30 31 36 ...
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID 0VB023
    failing bit : MDA0 8 MDB0 24 25 26 27 28 29 30 31 ...
[3  ] RW page (GUI)                                       : FAIL
    Error ID 0VB025
[4  ] RW channel (GUI)                                    : FAIL
    Error ID 0VB028
[5  ] Data mask                                           : FAIL
    Error ID 0VB006
[6  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID 0VC006
    failing bit : MDA0 8 MDB0 24 25 34 35 36 37 38 39 ...
[7  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID 0VC018
    failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 0 1 2 3 4 5 6 7 ...
[8  ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID 0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
    failing bit : MDB0 25 26 27 28 29 30 31 33 ...
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
    failing bit : MDA0 8 MDB0 24 25 26 27 28 29 30 34 ...
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
    failing bit : MDA0 8 MDB0 33 34 35 36 39 40 41 42 ...
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
[9  ] Line slopes/dir/P/solid                             : FAIL
    Error ID 0TR010
    failing bit : MDA0 8 MDB0 32 33 34 35 36 37 38 39 ...
    failing bit : MDA0 8 MDB0 32 33 34 35 36 37 39 40 ...
Failure detected.
[attach]174950[/attach]
作者: 凌寒    时间: 2010-6-23 23:02
你这是测多少次的结果呀,我们的都是测一次只出一行结果,这样看不明白
作者: 华发科技    时间: 2010-6-23 23:10
提示: 作者被禁止或删除 内容自动屏蔽
作者: 华发科技    时间: 2010-6-23 23:11
提示: 作者被禁止或删除 内容自动屏蔽
作者: 多多    时间: 2010-6-23 23:56
先查U8和U13,然后再测试一下
作者: 乐天    时间: 2010-6-23 23:56
查一下U13 U14
作者: bingye    时间: 2010-6-24 10:59
哪个牌子的?
作者: 马任知    时间: 2010-6-24 11:52
翔升的显卡
作者: 十月梅花开    时间: 2010-6-24 12:06
MDA0 8   是 U7,看看是不是有一个排阻坏,
MDB0 24至40后面....这些点都是有坏数据位,应该U13 U14 俩个都坏
