- 积分
- 804
- 下载分
- 分
- 威望
- 点
- 原创币
- 点
- 下载
- 次
- 上传
- 次
- 注册时间
- 2007-6-1
- 精华
请问是哪颗显存出了问题?只用过R3MEMID,没有用过R5MENID,所以看不懂,没有ABCD区域区分,郁闷
我怀疑是图中白色箭头的显存有问题,阻值跟其他的不同,其他的是500多欧姆,而他是800多欧姆,以下是检测结果:
R5MEMID version 1.03, (c) Copyright ATI Technologies Inc, 2006
Log file generation enabled to .\R5MEMID.LOG ...
Extended logging enabled ...
Reference data file (RDF) loading disabled ...
[1] Mem production test FB001
Failing Bits
rk0 chF: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
[2] Mem production test FB063
Failing Bits
[3] Mem production test FB064
Failing Bits
[4] Mem production test FB065
Failing Bits
[5] Mem production test FB066
Failing Bits
[6] Modified FB088
Failing Bits
[7] Modified FB091
Failing Bits
[1 ] Mem production test FB001 : FAIL
Error ID G0FB096
1024 x 768 - argb8888 (60 Hz): TEST FAILURE
Error count: total[16707309] chF[16707309]
[2 ] Mem production test FB063 : FAIL
Error ID G0FB096
Error count: total[964525] chF[964525]
[3 ] Mem production test FB064 : FAIL
Error ID G0FB096
Error count: total[954948] chF[954948]
[4 ] Mem production test FB065 : FAIL
Error ID G0FB096
Error count: total[2003789] chF[2003789]
[5 ] Mem production test FB066 : FAIL
Error ID G0FB096
Error count: total[2073448] chF[2073448]
[6 ] Modified FB088 : FAIL
Error ID G0FB088
Error count: total[97915] chF[97915]
[7 ] Modified FB091 : FAIL
Error ID G0FB091
Error count: total[97979] chF[97979]
TEST RESULT SUMMARY:
RV570/M68 (0x7288) detected.
256M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
Error ID G0FB096
Error ID G0FB096
Error ID G0FB096
Error ID G0FB096
Error ID G0FB096
Error ID G0FB088
Error ID G0FB091
Failure detected. |
