查看: 3238|回复: 1
[板卡资料]
BIOS自檢報警聲音含義[新]
发表于 2009-10-24 08:07:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
AMI報警聲含義
Beeps Description
嘟聲描述
Beep Code Meaning
報警聲含義:
1 beep
1響
DRAM refresh failure. There is a problem in the system memory or the motherboard. [本文來自 http://www.biosdiy.cn/]
DRAM刷新失敗。系統内存或者主闆有問題。
2 beeps
2響
Memory parity error. The parity circuit is not working properly.
内存奇偶檢驗錯誤。奇偶檢驗電路沒有正常工作。 [本文來自 http://www.biosdiy.cn/]
3 beeps
3響
Base 64K RAM failure. There is a problem with the first 64K of system memory.
基本64KB RAM 失敗。系統内存的第一個64KB有問題。
4 beeps
4響
System timer not operational. There is problem with the timer(s) that control functions on the motherboard.
系統計時器沒有工作。控制主闆功能的計時器有問題
5 beeps
5響
Processor failure. The system CPU has failed.
處理器失敗。系統CPU已經失敗。 [本文來自 http://www.biosdiy.cn/]
6 beeps
6響
Gate A20/keyboard controller failure. The keyboard IC controller has failed, preventing gate A20 from switching the processor to protect mode.
A20門/鍵盤 控制器失敗。鍵盤IC控制器已經失敗,防止門 A20轉換處理器到保護模式。
7 beeps
7響
Virtual mode exception error.
虛拟模式例外錯誤。 [本文來自 http://www.biosdiy.cn/]
8 beeps
8響
Video memory error. The BIOS cannot write to the frame buffer memory on the video card.
圖像内存錯誤。BIOS不能夠寫顯卡幀緩沖内存。
9 beeps
9響
ROM checksum error. The BIOS ROM chip on the motherboard is likely faulty.
ROM 檢查錯誤。主闆的BIOS ROM 芯片可能有錯誤。
10 beeps
10響
CMOS checksum error. Something on the motherboard is causing an error when trying to interact with the CMOS.
CMOS 檢查錯誤。當試圖與CMOS對比時主闆上的某些元件引起錯誤
11 beeps
11響
Bad cache memory. An error in the level 2 cache memory.
高速緩沖存儲器損壞。二級高速緩沖存儲器有錯誤。
1 long beep, 2 short 1長響2短響
Failure in the video system.
圖像系統失敗。 [本文來自 http://www.biosdiy.cn/]
1 long beep, 3 short1長響3短響
A failure has been detected in memory above 64K.
64KB以上内存空間檢測出錯誤。
1 long beep, 8 short
1長響8短響
Display test failure.
顯示檢測失敗。
Continuous beeping
連續不斷的響
A problem with the memory or video.
内存或者顯卡有問題。 [本文來自 http://www.biosdiy.cn/]
Awrad報警聲音含義
Beeps Description
嘟聲描述
Beep Code Meaning
報警聲含義:
1long, 2 short
1長,2短
Video adapter error Either video adapter is bad or is not seated properly. Also, check to ensure the monitor cable is connected properly.
顯卡錯誤,顯卡損壞或者沒有正确安裝。也可以,檢查确認顯示器電纜已經正确連接。 [本文來自 http://www.biosdiy.cn/]
Repeating (endless loop)
重複(無盡的循環)
Memory error Check for improperly seated or missing memory.
内存錯誤檢查是因爲不正确安裝或者缺少内存。
1long, 3short
1長3短
No video card or bad video RAM Reseat try replace the video card.
沒有顯卡或者顯卡 RAM複位損壞。嘗試更換顯卡。 [本文來自 http://www.biosdiy.cn/]
High frequency beeeps
高頻率響,
while running Overheated CPU Check the CPU fan for proper operation. Check the case for proper air flow.
運行使CPU過熱,檢查CPU風扇,檢查通風是否順暢 [本文來自 http://www.biosdiy.cn/]
Repeating High/Low CPU Either the CPU is not seated properly or the CPU is damaged. May also be due to excess heat. Check the CPU fan or BIOS settings for proper fan speed.
重複高/低 CPU 可能是CPU沒有安裝正确或者CPU損壞。也有可能是因爲特别熱。檢查CPU風扇或者BIOS設置,以便設置正确的風扇速度。
IBM Desktop報警聲音含義
Beeps Description
嘟聲描述
Beep Code Meaning
報警聲含義:
1 short
1短
Normal POST System is booting properly
正常上電自檢系統引導正确
2 short
2短
Initialization error Error code is displayed
初始化錯誤 錯誤代碼已顯示 [本文來自 http://www.biosdiy.cn/]
1 long, 1 short
1長1短
System board error
系統闆錯誤
1 long, 2 short
1長2短
Video adapter error
顯卡錯誤
1 long, 3 short
1長3短
EGA/VGA adapter error
EGA/VGA适配器錯誤
3 long
3長
3270 keyboard adapter error
3270 鍵盤适配器錯誤 [本文來自 http://www.biosdiy.cn/]
Continuous Power supply error Replace the power supply 連接電源供應錯誤,更換電源供應
No beep
無嘟嘟
Power supply Replace the power supply
電源供應更換電源供應 [本文來自 http://www.biosdiy.cn/]
IBM Thinkpad 報警聲音含義
Beeps Description
嘟聲描述
Beep Code Meaning
報警聲含義:
Continuous beeping
連續嘟嘟聲
System board failure系統闆失敗 www.biosdiy.cn
One beep
1嘟
Unreadable, blank or flashing LCD LCD connector problem; LCD backlight inverter failure; video adapter faulty; LCD assembly faulty; System board failure;  power supply failure
難以閱讀,空白或者LCD連接器問題 LCD背光變極器失敗 顯卡失敗LCD裝配失敗 系統闆失敗 電源供應失敗
One beep
1響
Message "Unable to access boot source" Boot device failure; system board failure
顯示信息“不能存取引導源”引導設備失敗;系統闆失敗
One long, two short beeps
1長,2短
System board failure; Video adapter problem; LCD assembly failure 系統闆失敗;顯卡問題;LCD裝配失敗www.biosdiy.cn
One long, four short beeps
1長,四短
Low battery voltage
低電池電壓
One beep every second
每兩秒1響
Low battery voltage
低電池電壓www.biosdiy.cn
发表于 2009-10-24 08:14:59 | 只看该作者 �
VERY Good....Thanks....
