查看: 51|回复: 0
控制电源不开机,强制开机后橙为8.53
发表于 昨天 21:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
  • 测量PFC输出310V,不正常;
  • 测量PFC芯片供电1.3V,正确电压12V,不正常;
  • 测供电小板(辅助电源)15V,正常。
四、测开机光耦12脚反向电压1V0,正向电压-1V0不正常。
五、测光耦后级控制PFC芯片供电的三极管Q39输出为1V,不正常。
六、测电源管理芯片ST9S313的27脚电压为4V9,正常;测4脚电压为0V,已经被开机信号拉低,正常;测3脚电压为3.9V,不正常,致使光耦12脚不导通,光耦34脚不能拉低Q39_B,为15V供电控制三极管Q39提供导通低电平。
七、短接ST9S313的34脚,强制开机,测PFC电压368V,正常;测PFC芯片VCC为12V,正常;测电源输出黄线=11V,稍低,测橙线为8.65V,不正常,下一步应查电压反馈电路。
八、开机光耦旁边的光耦为稳压反馈光耦,测12脚正向电压为1V,正常,说明电压反馈电路正在工作。
九、查稳压光耦前级431及分压补偿电路,发现一个电阻阻值比正常值小六倍多,大家都知道,电阻正常烧毁,阻值会升高,阻值降低,只能说明此电源长期工作在潮湿环境,致使电阻背胶受潮导电,与所粘贴的电阻形成并联电阻,测量值表现为比正常值低很多。拆下此电阻,除胶,焊回,清洗,开机:输出黄为12V,橙为3V3,红为5V,搞定。
weibo.com/ttarticle/p/show?id=2309405360097500463171
weibo.com/ttarticle/p/show?id=2309405360097743470782
weibo.com/ttarticle/p/show?id=2309405360097990934604
weibo.com/ttarticle/p/show?id=2309405360098238660634
weibo.com/ttarticle/p/show?id=2309405360098741977250
weibo.com/ttarticle/p/show?id=2309405360098989441190
weibo.com/ttarticle/p/show?id=2309405360099236643010
weibo.com/ttarticle/p/show?id=2309405360099492757542
weibo.com/ttarticle/p/show?id=2309405360099736027278
weibo.com/ttarticle/p/show?id=2309405360099983491123
weibo.com/ttarticle/p/show?id=2309405360100234887348
weibo.com/ttarticle/p/show?id=2309405360100486545638
weibo.com/ttarticle/p/show?id=2309405360100734271533
weibo.com/ttarticle/p/show?id=2309405360100977279246
weibo.com/ttarticle/p/show?id=2309405360101224743072
weibo.com/ttarticle/p/show?id=2309405360101480595654
weibo.com/ttarticle/p/show?id=2309405360101728321539
weibo.com/ttarticle/p/show?id=2309405360101971329092
weibo.com/ttarticle/p/show?id=2309405360102403342403
weibo.com/ttarticle/p/show?id=2309405360102650806407
weibo.com/ttarticle/p/show?id=2309405360102898270251
weibo.com/ttarticle/p/show?id=2309405360103149928637
weibo.com/ttarticle/p/show?id=2309405360103397392391
weibo.com/ttarticle/p/show?id=2309405360103645118513
weibo.com/ttarticle/p/show?id=2309405360103900709017
weibo.com/ttarticle/p/show?id=2309405360104672460821
weibo.com/ttarticle/p/show?id=2309405360104924119051
weibo.com/ttarticle/p/show?id=2309405360105167388987
weibo.com/ttarticle/p/show?id=2309405360105419309063
weibo.com/ttarticle/p/show?id=2309405360105670705371
weibo.com/ttarticle/p/show?id=2309405360105956180141
weibo.com/ttarticle/p/show?id=2309405360106203643988
weibo.com/ttarticle/p/show?id=2309405360106451107952
weibo.com/ttarticle/p/show?id=2309405360106803167448
weibo.com/ttarticle/p/show?id=2309405360107059282003
weibo.com/ttarticle/p/show?id=2309405360107302289584
weibo.com/ttarticle/p/show?id=2309405360107549753462
weibo.com/ttarticle/p/show?id=2309405360107801673909
weibo.com/ttarticle/p/show?id=2309405360108292407398
weibo.com/ttarticle/p/show?id=2309405360108539871254
weibo.com/ttarticle/p/show?id=2309405360109042925772
weibo.com/ttarticle/p/show?id=2309405360109290389630
weibo.com/ttarticle/p/show?id=2309405360043788206376
weibo.com/ttarticle/p/show?id=2309405360044048253173
weibo.com/ttarticle/p/show?id=2309405360044295716927
weibo.com/ttarticle/p/show?id=2309405360044538986695
weibo.com/ttarticle/p/show?id=2309405360044786188329
weibo.com/ttarticle/p/show?id=2309405360045063274574
weibo.com/ttarticle/p/show?id=2309405360045310476331
weibo.com/ttarticle/p/show?id=2309405360045553746241
weibo.com/ttarticle/p/show?id=2309405360045805666485
weibo.com/ttarticle/p/show?id=2309405360046061519086
weibo.com/ttarticle/p/show?id=2309405360046308983052
weibo.com/ttarticle/p/show?id=2309405360046560378907
weibo.com/ttarticle/p/show?id=2309405360046803648728
weibo.com/ttarticle/p/show?id=2309405360047055306915
weibo.com/ttarticle/p/show?id=2309405360047302770697
weibo.com/ttarticle/p/show?id=2309405360047546040402
weibo.com/ttarticle/p/show?id=2309405360047789572239
weibo.com/ttarticle/p/show?id=2309405360048070590858
weibo.com/ttarticle/p/show?id=2309405360048318054540
weibo.com/ttarticle/p/show?id=2309405360048586227907
weibo.com/ttarticle/p/show?id=2309405360048833954177
weibo.com/ttarticle/p/show?id=2309405360049110515899
weibo.com/ttarticle/p/show?id=2309405360049366630622
weibo.com/ttarticle/p/show?id=2309405360049689592041
weibo.com/ttarticle/p/show?id=2309405360049940987921
weibo.com/ttarticle/p/show?id=2309405360050192646422
weibo.com/ttarticle/p/show?id=2309405360050461343835
weibo.com/ttarticle/p/show?id=2309405360050893357104
weibo.com/ttarticle/p/show?id=2309405360051228639411
weibo.com/ttarticle/p/show?id=2309405360051476103264
weibo.com/ttarticle/p/show?id=2309405360051723567161
weibo.com/ttarticle/p/show?id=2309405360051983876350
weibo.com/ttarticle/p/show?id=2309405360052231077900
weibo.com/ttarticle/p/show?id=2309405360052474609838
weibo.com/ttarticle/p/show?id=2309405360052893778072
weibo.com/ttarticle/p/show?id=2309405360053145436219
weibo.com/ttarticle/p/show?id=2309405360053392900179
weibo.com/ttarticle/p/show?id=2309405360053971714202
weibo.com/ttarticle/p/show?id=2309405360054223372387
weibo.com/ttarticle/p/show?id=2309405360054466904271
weibo.com/ttarticle/p/show?id=2309405360054726951074
weibo.com/ttarticle/p/show?id=2309405360054974152873
weibo.com/ttarticle/p/show?id=2309405360055230267582
weibo.com/ttarticle/p/show?id=2309405360055561617467
weibo.com/ttarticle/p/show?id=2309405360055821664293
weibo.com/ttarticle/p/show?id=2309405360056064671960
weibo.com/ttarticle/p/show?id=2309405360056320524392
weibo.com/ttarticle/p/show?id=2309405360056568250373
weibo.com/ttarticle/p/show?id=2309405360056777965639
weibo.com/ttarticle/p/show?id=2309405360056983224334
weibo.com/ttarticle/p/show?id=2309405360057192939597
weibo.com/ttarticle/p/show?id=2309405360057394266211
weibo.com/ttarticle/p/show?id=2309405360057599787131
weibo.com/ttarticle/p/show?id=2309405360057809502299
weibo.com/ttarticle/p/show?id=2309405360058032062640
weibo.com/ttarticle/p/show?id=2309405360058237321361
weibo.com/ttarticle/p/show?id=2309405360058442842251
weibo.com/ttarticle/p/show?id=2309405360067313795239
weibo.com/ttarticle/p/show?id=2309405360067347611885
weibo.com/ttarticle/p/show?id=2309405360067385360423
weibo.com/ttarticle/p/show?id=2309405360067418652709
weibo.com/ttarticle/p/show?id=2309405360067452207261
weibo.com/ttarticle/p/show?id=2309405360067485761771
weibo.com/ttarticle/p/show?id=2309405360067523772434
weibo.com/ttarticle/p/show?id=2309405360067557064732
weibo.com/ttarticle/p/show?id=2309405360067590881387
weibo.com/ttarticle/p/show?id=2309405360067624435843
weibo.com/ttarticle/p/show?id=2309405360067657990315
weibo.com/ttarticle/p/show?id=2309405360067695476755
weibo.com/ttarticle/p/show?id=2309405360067733487852
weibo.com/ttarticle/p/show?id=2309405360067770974353
weibo.com/ttarticle/p/show?id=2309405360067804528814
weibo.com/ttarticle/p/show?id=2309405360067838345342
weibo.com/ttarticle/p/show?id=2309405360067909648421
weibo.com/ttarticle/p/show?id=2309405360067942940947
weibo.com/ttarticle/p/show?id=2309405360067976757406
weibo.com/ttarticle/p/show?id=2309405360068022894702
weibo.com/ttarticle/p/show?id=2309405360068064575644
weibo.com/ttarticle/p/show?id=2309405360068102586469
weibo.com/ttarticle/p/show?id=2309405360068135878941
weibo.com/ttarticle/p/show?id=2309405360068182278188
weibo.com/ttarticle/p/show?id=2309405360068228153366
weibo.com/ttarticle/p/show?id=2309405360068261707902
weibo.com/ttarticle/p/show?id=2309405360068295524498
weibo.com/ttarticle/p/show?id=2309405360068333273121
weibo.com/ttarticle/p/show?id=2309405360094664851532
weibo.com/ttarticle/p/show?id=2309405360094912315540
weibo.com/ttarticle/p/show?id=2309405360095176556559
weibo.com/ttarticle/p/show?id=2309405360095428477009
weibo.com/ttarticle/p/show?id=2309405360095675940905
weibo.com/ttarticle/p/show?id=2309405360095919210697
weibo.com/ttarticle/p/show?id=2309405360096166412314
weibo.com/ttarticle/p/show?id=2309405360096418070666
weibo.com/ttarticle/p/show?id=2309405360096661602546
weibo.com/ttarticle/p/show?id=2309405360096912998532
weibo.com/ttarticle/p/show?id=2309405360097156268222
weibo.com/ttarticle/p/show?id=2309405360061601153045
weibo.com/ttarticle/p/show?id=2309405360061643096070
weibo.com/ttarticle/p/show?id=2309405360061680845046
weibo.com/ttarticle/p/show?id=2309405360061722787865
weibo.com/ttarticle/p/show?id=2309405360061760798875
weibo.com/ttarticle/p/show?id=2309405360061798547624
weibo.com/ttarticle/p/show?id=2309405360061836296436
weibo.com/ttarticle/p/show?id=2309405360061878239238
weibo.com/ttarticle/p/show?id=2309405360061915725910
weibo.com/ttarticle/p/show?id=2309405360061957931019
weibo.com/ttarticle/p/show?id=2309405360061999611999
weibo.com/ttarticle/p/show?id=2309405360062037360897
weibo.com/ttarticle/p/show?id=2309405360062075109578
weibo.com/ttarticle/p/show?id=2309405360062117314831
weibo.com/ttarticle/p/show?id=2309405360062154801278
weibo.com/ttarticle/p/show?id=2309405360062352195855
weibo.com/ttarticle/p/show?id=2309405360062402265152
weibo.com/ttarticle/p/show?id=2309405360062452596746
weibo.com/ttarticle/p/show?id=2309405360062498996249
weibo.com/ttarticle/p/show?id=2309405360062540677168
weibo.com/ttarticle/p/show?id=2309405360062599397449
weibo.com/ttarticle/p/show?id=2309405360062662312026
weibo.com/ttarticle/p/show?id=2309405360062767431733
weibo.com/ttarticle/p/show?id=2309405360062830346292
weibo.com/ttarticle/p/show?id=2309405360062884872358
weibo.com/ttarticle/p/show?id=2309405360062930747443
weibo.com/ttarticle/p/show?id=2309405360062972690598
weibo.com/ttarticle/p/show?id=2309405360063077548042
weibo.com/ttarticle/p/show?id=2309405360063119753558
weibo.com/ttarticle/p/show?id=2309405360063169822800
weibo.com/ttarticle/p/show?id=2309405360063212027944
weibo.com/ttarticle/p/show?id=2309405360063257903160
weibo.com/ttarticle/p/show?id=2309405360063304302704
weibo.com/ttarticle/p/show?id=2309405360063350440262
weibo.com/ttarticle/p/show?id=2309405360063396315211
weibo.com/ttarticle/p/show?id=2309405360063442714633
weibo.com/ttarticle/p/show?id=2309405360063526600875
weibo.com/ttarticle/p/show?id=2309405360063568544002
weibo.com/ttarticle/p/show?id=2309405360063610224698
weibo.com/ttarticle/p/show?id=2309405360063694110800
weibo.com/ttarticle/p/show?id=2309405360065803845807
weibo.com/ttarticle/p/show?id=2309405360065845788711
weibo.com/ttarticle/p/show?id=2309405360065887993973
weibo.com/ttarticle/p/show?id=2309405360065925742711
weibo.com/ttarticle/p/show?id=2309405360065963229453
weibo.com/ttarticle/p/show?id=2309405360066018017317
weibo.com/ttarticle/p/show?id=2309405360066055766217
weibo.com/ttarticle/p/show?id=2309405360066101903433
weibo.com/ttarticle/p/show?id=2309405360066143846695
weibo.com/ttarticle/p/show?id=2309405360066185527373
weibo.com/ttarticle/p/show?id=2309405360066223538189
weibo.com/ttarticle/p/show?id=2309405360066261024823
weibo.com/ttarticle/p/show?id=2309405360066303230108
weibo.com/ttarticle/p/show?id=2309405360066344910902
weibo.com/ttarticle/p/show?comment=1&id=2309405360097995129066
weibo.com/ttarticle/p/show?id=2309405360098041528378
weibo.com/ttarticle/p/show?id=2309405360097995129066
weibo.com/ttarticle/p/show?comment=1&id=2309405360098041528378
weibo.com/ttarticle/p/show?id=2309405360098087403525
weibo.com/ttarticle/p/show?comment=1&id=2309405360098087403525
weibo.com/ttarticle/p/show?id=2309405360098129346725
weibo.com/ttarticle/p/show?comment=1&id=2309405360098129346725
weibo.com/ttarticle/p/show?id=2309405360098175746131
weibo.com/ttarticle/p/show?comment=1&id=2309405360098175746131
weibo.com/ttarticle/p/show?id=2309405360098213232828
weibo.com/ttarticle/p/show?comment=1&id=2309405360098213232828
weibo.com/ttarticle/p/show?comment=1&id=2309405360098251243644
weibo.com/ttarticle/p/show?id=2309405360098251243644
weibo.com/ttarticle/p/show?id=2309405360098288730142
weibo.com/ttarticle/p/show?comment=1&id=2309405360098288730142
weibo.com/ttarticle/p/show?id=2309405360098322284675
weibo.com/ttarticle/p/show?comment=1&id=2309405360098322284675
weibo.com/ttarticle/p/show?id=2309405360098356101196
weibo.com/ttarticle/p/show?comment=1&id=2309405360098356101196
weibo.com/ttarticle/p/show?id=2309405360098393849989
weibo.com/ttarticle/p/show?comment=1&id=2309405360098393849989
weibo.com/ttarticle/p/show?id=2309405360098431336496
weibo.com/ttarticle/p/show?comment=1&id=2309405360098431336496
weibo.com/ttarticle/p/show?id=2309405360098464891044
weibo.com/ttarticle/p/show?comment=1&id=2309405360098464891044
weibo.com/ttarticle/p/show?id=2309405360098502639698
weibo.com/ttarticle/p/show?comment=1&id=2309405360098502639698
weibo.com/ttarticle/p/show?id=2309405360098540388370
weibo.com/ttarticle/p/show?comment=1&id=2309405360098540388370
weibo.com/ttarticle/p/show?id=2309405360140688949376
weibo.com/ttarticle/p/show?comment=1&id=2309405360140688949376
weibo.com/ttarticle/p/show?id=2309405360140722766091
weibo.com/ttarticle/p/show?comment=1&id=2309405360140722766091
weibo.com/ttarticle/p/show?id=2309405360140760514670
weibo.com/ttarticle/p/show?comment=1&id=2309405360140760514670
weibo.com/ttarticle/p/show?id=2309405360140798263435
weibo.com/ttarticle/p/show?comment=1&id=2309405360140798263435
weibo.com/ttarticle/p/show?id=2309405360140835750058
weibo.com/ttarticle/p/show?comment=1&id=2309405360140835750058
weibo.com/ttarticle/p/show?id=2309405360140873498641
weibo.com/ttarticle/p/show?comment=1&id=2309405360140873498641
weibo.com/ttarticle/p/show?id=2309405360140907315333
weibo.com/ttarticle/p/show?comment=1&id=2309405360140907315333
weibo.com/ttarticle/p/show?id=2309405360140944801945
weibo.com/ttarticle/p/show?comment=1&id=2309405360140944801945
weibo.com/ttarticle/p/show?id=2309405360140982812761
weibo.com/ttarticle/p/show?comment=1&id=2309405360140982812761
weibo.com/ttarticle/p/show?id=2309405360141016367307
weibo.com/ttarticle/p/show?comment=1&id=2309405360141016367307
weibo.com/ttarticle/p/show?id=2309405360141054115872
weibo.com/ttarticle/p/show?comment=1&id=2309405360141054115872
weibo.com/ttarticle/p/show?id=2309405360141087408177
weibo.com/ttarticle/p/show?comment=1&id=2309405360141087408177
weibo.com/ttarticle/p/show?id=2309405360141125419208
weibo.com/ttarticle/p/show?comment=1&id=2309405360141125419208
weibo.com/ttarticle/p/show?id=2309405360141171294323
weibo.com/ttarticle/p/show?comment=1&id=2309405360141171294323
weibo.com/ttarticle/p/show?id=2309405360141217693722
weibo.com/ttarticle/p/show?comment=1&id=2309405360141217693722
weibo.com/ttarticle/p/show?comment=1&id=2309405360061601153045
weibo.com/ttarticle/p/show?comment=1&id=2309405360061643096070
weibo.com/ttarticle/p/show?comment=1&id=2309405360061680845046
weibo.com/ttarticle/p/show?comment=1&id=2309405360061722787865
weibo.com/ttarticle/p/show?comment=1&id=2309405360061760798875
weibo.com/ttarticle/p/show?comment=1&id=2309405360061798547624
weibo.com/ttarticle/p/show?comment=1&id=2309405360061836296436
weibo.com/ttarticle/p/show?comment=1&id=2309405360061878239238
weibo.com/ttarticle/p/show?comment=1&id=2309405360061915725910
weibo.com/ttarticle/p/show?comment=1&id=2309405360061957931019
weibo.com/ttarticle/p/show?comment=1&id=2309405360061999611999
weibo.com/ttarticle/p/show?comment=1&id=2309405360062037360897
weibo.com/ttarticle/p/show?comment=1&id=2309405360062075109578
weibo.com/ttarticle/p/show?comment=1&id=2309405360062117314831
weibo.com/ttarticle/p/show?comment=1&id=2309405360062154801278
weibo.com/ttarticle/p/show?comment=1&id=2309405360062352195855
weibo.com/ttarticle/p/show?comment=1&id=2309405360062402265152
weibo.com/ttarticle/p/show?comment=1&id=2309405360062452596746
weibo.com/ttarticle/p/show?comment=1&id=2309405360062498996249
weibo.com/ttarticle/p/show?comment=1&id=2309405360062540677168
weibo.com/ttarticle/p/show?comment=1&id=2309405360062599397449
weibo.com/ttarticle/p/show?comment=1&id=2309405360062662312026
weibo.com/ttarticle/p/show?comment=1&id=2309405360062767431733
weibo.com/ttarticle/p/show?comment=1&id=2309405360062830346292
weibo.com/ttarticle/p/show?comment=1&id=2309405360062884872358
weibo.com/ttarticle/p/show?comment=1&id=2309405360062930747443
weibo.com/ttarticle/p/show?comment=1&id=2309405360062972690598
weibo.com/ttarticle/p/show?comment=1&id=2309405360063077548042
weibo.com/ttarticle/p/show?comment=1&id=2309405360063119753558
weibo.com/ttarticle/p/show?comment=1&id=2309405360063169822800
weibo.com/ttarticle/p/show?comment=1&id=2309405360063212027944
weibo.com/ttarticle/p/show?comment=1&id=2309405360063257903160
weibo.com/ttarticle/p/show?comment=1&id=2309405360063304302704
weibo.com/ttarticle/p/show?comment=1&id=2309405360063350440262
weibo.com/ttarticle/p/show?comment=1&id=2309405360063396315211
weibo.com/ttarticle/p/show?comment=1&id=2309405360063442714633
weibo.com/ttarticle/p/show?comment=1&id=2309405360063526600875
weibo.com/ttarticle/p/show?comment=1&id=2309405360063568544002
weibo.com/ttarticle/p/show?comment=1&id=2309405360063610224698
weibo.com/ttarticle/p/show?comment=1&id=2309405360063694110800
weibo.com/ttarticle/p/show?comment=1&id=2309405360065803845807
weibo.com/ttarticle/p/show?comment=1&id=2309405360065845788711
weibo.com/ttarticle/p/show?comment=1&id=2309405360065887993973
weibo.com/ttarticle/p/show?comment=1&id=2309405360065925742711
weibo.com/ttarticle/p/show?comment=1&id=2309405360065963229453
weibo.com/ttarticle/p/show?comment=1&id=2309405360066018017317
weibo.com/ttarticle/p/show?comment=1&id=2309405360066055766217
weibo.com/ttarticle/p/show?comment=1&id=2309405360066101903433
weibo.com/ttarticle/p/show?comment=1&id=2309405360066143846695
weibo.com/ttarticle/p/show?comment=1&id=2309405360066185527373
weibo.com/ttarticle/p/show?comment=1&id=2309405360066223538189
weibo.com/ttarticle/p/show?comment=1&id=2309405360066261024823
weibo.com/ttarticle/p/show?comment=1&id=2309405360066303230108
weibo.com/ttarticle/p/show?id=2309405360066387116074
weibo.com/ttarticle/p/show?comment=1&id=2309405360066344910902
weibo.com/ttarticle/p/show?comment=1&id=2309405360066387116074
weibo.com/ttarticle/p/show?comment=1&id=2309405360066424864823
weibo.com/ttarticle/p/show?id=2309405360066424864823
weibo.com/ttarticle/p/show?id=2309405360066462351576
weibo.com/ttarticle/p/show?comment=1&id=2309405360066462351576
weibo.com/ttarticle/p/show?id=2309405360066504556562
weibo.com/ttarticle/p/show?comment=1&id=2309405360066504556562
weibo.com/ttarticle/p/show?id=2309405360066542305501
weibo.com/ttarticle/p/show?comment=1&id=2309405360066542305501
weibo.com/ttarticle/p/show?id=2309405360066584248373
weibo.com/ttarticle/p/show?comment=1&id=2309405360066584248373
weibo.com/ttarticle/p/show?id=2309405360066630385874
weibo.com/ttarticle/p/show?comment=1&id=2309405360066630385874
weibo.com/ttarticle/p/show?id=2309405360066718204200
weibo.com/ttarticle/p/show?comment=1&id=2309405360066718204200
weibo.com/ttarticle/p/show?id=2309405360066764603549
weibo.com/ttarticle/p/show?comment=1&id=2309405360066764603549
weibo.com/ttarticle/p/show?id=2309405360066806546482
weibo.com/ttarticle/p/show?comment=1&id=2309405360066806546482
weibo.com/ttarticle/p/show?id=2309405360066848489502
weibo.com/ttarticle/p/show?comment=1&id=2309405360066848489502
weibo.com/ttarticle/p/show?id=2309405360066890432668
weibo.com/ttarticle/p/show?comment=1&id=2309405360066890432668
weibo.com/ttarticle/p/show?id=2309405360066928181533
weibo.com/ttarticle/p/show?comment=1&id=2309405360066928181533
weibo.com/ttarticle/p/show?id=2309405360066974056581
weibo.com/ttarticle/p/show?comment=1&id=2309405360066974056581
weibo.com/ttarticle/p/show?id=2309405360081658577071
weibo.com/ttarticle/p/show?comment=1&id=2309405360081658577071
weibo.com/ttarticle/p/show?id=2309405360081792794918
weibo.com/ttarticle/p/show?comment=1&id=2309405360081792794918
weibo.com/ttarticle/p/show?id=2309405360081830281435
weibo.com/ttarticle/p/show?comment=1&id=2309405360081830281435
weibo.com/ttarticle/p/show?id=2309405360081868030160
weibo.com/ttarticle/p/show?comment=1&id=2309405360081868030160
weibo.com/ttarticle/p/show?id=2309405360081914167456
weibo.com/ttarticle/p/show?comment=1&id=2309405360081914167456
weibo.com/ttarticle/p/show?id=2309405360081956372592
weibo.com/ttarticle/p/show?comment=1&id=2309405360081956372592
weibo.com/ttarticle/p/show?comment=1&id=2309405360082002247705
weibo.com/ttarticle/p/show?id=2309405360082002247705
weibo.com/ttarticle/p/show?id=2309405360082048385046
weibo.com/ttarticle/p/show?comment=1&id=2309405360082048385046
weibo.com/ttarticle/p/show?id=2309405360082098716729
weibo.com/ttarticle/p/show?comment=1&id=2309405360082098716729
weibo.com/ttarticle/p/show?id=2309405360082144854046
weibo.com/ttarticle/p/show?comment=1&id=2309405360082144854046
weibo.com/ttarticle/p/show?id=2309405360082190991572
weibo.com/ttarticle/p/show?comment=1&id=2309405360082190991572
weibo.com/ttarticle/p/show?id=2309405360082237128879
weibo.com/ttarticle/p/show?comment=1&id=2309405360082237128879
weibo.com/ttarticle/p/show?id=2309405360082287722682
weibo.com/ttarticle/p/show?comment=1&id=2309405360082287722682
weibo.com/ttarticle/p/show?id=2309405360082338054252
weibo.com/ttarticle/p/show?comment=1&id=2309405360082338054252
weibo.com/ttarticle/p/show?id=2309405360082438717468
weibo.com/ttarticle/p/show?comment=1&id=2309405360082438717468
weibo.com/ttarticle/p/show?id=2309405360082488787019
weibo.com/ttarticle/p/show?comment=1&id=2309405360082488787019
weibo.com/ttarticle/p/show?id=2309405360082598101030
weibo.com/ttarticle/p/show?comment=1&id=2309405360082598101030
weibo.com/ttarticle/p/show?id=2309405360082656559312
weibo.com/ttarticle/p/show?comment=1&id=2309405360082656559312
weibo.com/ttarticle/p/show?id=2309405360082711085379
weibo.com/ttarticle/p/show?comment=1&id=2309405360082711085379
weibo.com/ttarticle/p/show?comment=1&id=2309405360082765611079
weibo.com/ttarticle/p/show?id=2309405360082765611079
weibo.com/ttarticle/p/show?id=2309405360082820137001
weibo.com/ttarticle/p/show?comment=1&id=2309405360082820137001
weibo.com/ttarticle/p/show?id=2309405360082887245899
weibo.com/ttarticle/p/show?comment=1&id=2309405360082887245899
weibo.com/ttarticle/p/show?id=2309405360082933645319
weibo.com/ttarticle/p/show?comment=1&id=2309405360082933645319
weibo.com/ttarticle/p/show?id=2309405360082975326325
weibo.com/ttarticle/p/show?comment=1&id=2309405360082975326325
weibo.com/ttarticle/p/show?id=2309405360083021463598
weibo.com/ttarticle/p/show?comment=1&id=2309405360083021463598
weibo.com/ttarticle/p/show?id=2309405360179281002691
weibo.com/ttarticle/p/show?comment=1&id=2309405360179281002691
weibo.com/ttarticle/p/show?id=2309405360179465551928
weibo.com/ttarticle/p/show?comment=1&id=2309405360179465551928
weibo.com/ttarticle/p/show?comment=1&id=2309405360179645644964
weibo.com/ttarticle/p/show?id=2309405360179645644964
weibo.com/ttarticle/p/show?id=2309405360179830194209
weibo.com/ttarticle/p/show?comment=1&id=2309405360179830194209
weibo.com/ttarticle/p/show?id=2309405360180023394399
weibo.com/ttarticle/p/show?comment=1&id=2309405360180023394399
weibo.com/ttarticle/p/show?id=2309405360189686808968
weibo.com/ttarticle/p/show?comment=1&id=2309405360189686808968
weibo.com/ttarticle/p/show?id=2309405360189871358067
weibo.com/ttarticle/p/show?comment=1&id=2309405360189871358067
weibo.com/ttarticle/p/show?id=2309405360190051713259
weibo.com/ttarticle/p/show?comment=1&id=2309405360190051713259
weibo.com/ttarticle/p/show?id=2309405360190232330624
weibo.com/ttarticle/p/show?comment=1&id=2309405360190232330624
weibo.com/ttarticle/p/show?comment=1&id=2309405360190421074211
weibo.com/ttarticle/p/show?id=2309405360190421074211
weibo.com/ttarticle/p/show?id=2309405360190789910586
weibo.com/ttarticle/p/show?comment=1&id=2309405360190789910586
weibo.com/ttarticle/p/show?id=2309405360190970527955
weibo.com/ttarticle/p/show?comment=1&id=2309405360190970527955
weibo.com/ttarticle/p/show?id=2309405360191155077168
weibo.com/ttarticle/p/show?comment=1&id=2309405360191155077168
weibo.com/ttarticle/p/show?id=2309405360191343558763
weibo.com/ttarticle/p/show?comment=1&id=2309405360191343558763
weibo.com/ttarticle/p/show?comment=1&id=2309405360191524176155
weibo.com/ttarticle/p/show?id=2309405360191524176155
weibo.com/ttarticle/p/show?id=2309405360191717113876
weibo.com/ttarticle/p/show?comment=1&id=2309405360191717113876
weibo.com/ttarticle/p/show?id=2309405360191897469043
weibo.com/ttarticle/p/show?comment=1&id=2309405360191897469043
weibo.com/ttarticle/p/show?comment=1&id=2309405360192082018342
weibo.com/ttarticle/p/show?id=2309405360192082018342
weibo.com/ttarticle/p/show?id=2309405360192270762015
weibo.com/ttarticle/p/show?comment=1&id=2309405360192270762015
weibo.com/ttarticle/p/show?id=2309405360192450855146
weibo.com/ttarticle/p/show?comment=1&id=2309405360192450855146
weibo.com/ttarticle/p/show?id=2309405360192635666441
weibo.com/ttarticle/p/show?comment=1&id=2309405360192635666441
weibo.com/ttarticle/p/show?id=2309405360192815759714
weibo.com/ttarticle/p/show?comment=1&id=2309405360192815759714
weibo.com/ttarticle/p/show?id=2309405360193000570923
weibo.com/ttarticle/p/show?comment=1&id=2309405360193000570923
weibo.com/ttarticle/p/show?comment=1&id=2309405360193189052598
weibo.com/ttarticle/p/show?id=2309405360193189052598
weibo.com/ttarticle/p/show?id=2309405360193373864043
weibo.com/ttarticle/p/show?comment=1&id=2309405360193373864043
weibo.com/ttarticle/p/show?id=2309405360193558151378
weibo.com/ttarticle/p/show?comment=1&id=2309405360193558151378
weibo.com/ttarticle/p/show?id=2309405360193738506501
weibo.com/ttarticle/p/show?comment=1&id=2309405360193738506501
weibo.com/ttarticle/p/show?id=2309405360193923317949
weibo.com/ttarticle/p/show?comment=1&id=2309405360193923317949
weibo.com/ttarticle/p/show?id=2309405360194120187969
weibo.com/ttarticle/p/show?comment=1&id=2309405360194120187969
weibo.com/ttarticle/p/show?id=2309405360194300543641
weibo.com/ttarticle/p/show?comment=1&id=2309405360194300543641
weibo.com/ttarticle/p/show?id=2309405360194485092486
weibo.com/ttarticle/p/show?comment=1&id=2309405360194485092486
weibo.com/ttarticle/p/show?id=2309405360194669642147
weibo.com/ttarticle/p/show?comment=1&id=2309405360194669642147
weibo.com/ttarticle/p/show?id=2309405360194854453571
weibo.com/ttarticle/p/show?comment=1&id=2309405360194854453571
weibo.com/ttarticle/p/show?id=2309405360195047129378
weibo.com/ttarticle/p/show?comment=1&id=2309405360195047129378
weibo.com/ttarticle/p/show?id=2309405360195231678569
weibo.com/ttarticle/p/show?comment=1&id=2309405360195231678569
weibo.com/ttarticle/p/show?comment=1&id=2309405360195412033659
weibo.com/ttarticle/p/show?id=2309405360195412033659
weibo.com/ttarticle/p/show?id=2309405360195596583521
weibo.com/ttarticle/p/show?comment=1&id=2309405360195596583521
weibo.com/ttarticle/p/show?id=2309405360195781394715
weibo.com/ttarticle/p/show?comment=1&id=2309405360195781394715
weibo.com/ttarticle/p/show?id=2309405360195969876423
weibo.com/ttarticle/p/show?comment=1&id=2309405360195969876423
weibo.com/ttarticle/p/show?id=2309405360172008079565
weibo.com/ttarticle/p/show?comment=1&id=2309405360172008079565
weibo.com/ttarticle/p/show?id=2309405360172171395230
weibo.com/ttarticle/p/show?comment=1&id=2309405360172171395230
weibo.com/ttarticle/p/show?id=2309405360172335235173
weibo.com/ttarticle/p/show?comment=1&id=2309405360172335235173
weibo.com/ttarticle/p/show?id=2309405360172494356776
weibo.com/ttarticle/p/show?comment=1&id=2309405360172494356776
weibo.com/ttarticle/p/show?id=2309405360172657934479
weibo.com/ttarticle/p/show?comment=1&id=2309405360172657934479
weibo.com/ttarticle/p/show?id=2309405360172834357267
weibo.com/ttarticle/p/show?comment=1&id=2309405360172834357267
weibo.com/ttarticle/p/show?id=2309405360173006061819
weibo.com/ttarticle/p/show?comment=1&id=2309405360173006061819
weibo.com/ttarticle/p/show?id=2309405360173173833914
weibo.com/ttarticle/p/show?id=2309405360173341606050
weibo.com/ttarticle/p/show?comment=1&id=2309405360173341606050
weibo.com/ttarticle/p/show?comment=1&id=2309405360173173833914
weibo.com/ttarticle/p/show?id=2309405360173509378149
weibo.com/ttarticle/p/show?comment=1&id=2309405360173509378149
weibo.com/ttarticle/p/show?id=2309405360173677150301
weibo.com/ttarticle/p/show?comment=1&id=2309405360173677150301
weibo.com/ttarticle/p/show?comment=1&id=2309405360173840728167
weibo.com/ttarticle/p/show?id=2309405360173840728167
weibo.com/ttarticle/p/show?id=2309405360174004305962
weibo.com/ttarticle/p/show?comment=1&id=2309405360174004305962
weibo.com/ttarticle/p/show?id=2309405360174163951769
weibo.com/ttarticle/p/show?comment=1&id=2309405360174163951769
weibo.com/ttarticle/p/show?id=2309405360174327529496
weibo.com/ttarticle/p/show?comment=1&id=2309405360174327529496
weibo.com/ttarticle/p/show?id=2309405360174503690265
weibo.com/ttarticle/p/show?comment=1&id=2309405360174503690265
weibo.com/ttarticle/p/show?id=2309405360174667268107
weibo.com/ttarticle/p/show?comment=1&id=2309405360174667268107
weibo.com/ttarticle/p/show?id=2309405360174826389686
weibo.com/ttarticle/p/show?comment=1&id=2309405360174826389686
weibo.com/ttarticle/p/show?id=2309405360174989967517
weibo.com/ttarticle/p/show?comment=1&id=2309405360174989967517
weibo.com/ttarticle/p/show?id=2309405360175153807522
weibo.com/ttarticle/p/show?comment=1&id=2309405360175153807522
weibo.com/ttarticle/p/show?id=2309405360175325511722
weibo.com/ttarticle/p/show?comment=1&id=2309405360175325511722
weibo.com/ttarticle/p/show?id=2309405360175484895320
weibo.com/ttarticle/p/show?comment=1&id=2309405360175484895320
weibo.com/ttarticle/p/show?id=2309405360175648735306
weibo.com/ttarticle/p/show?comment=1&id=2309405360175648735306
weibo.com/ttarticle/p/show?id=2309405360175808119051
weibo.com/ttarticle/p/show?comment=1&id=2309405360175808119051
weibo.com/ttarticle/p/show?id=2309405360175971696699
weibo.com/ttarticle/p/show?comment=1&id=2309405360175971696699
weibo.com/ttarticle/p/show?id=2309405360176139468934
weibo.com/ttarticle/p/show?comment=1&id=2309405360176139468934
weibo.com/ttarticle/p/show?id=2309405360176311435412
weibo.com/ttarticle/p/show?comment=1&id=2309405360176311435412
weibo.com/ttarticle/p/show?id=2309405360176483401970
weibo.com/ttarticle/p/show?id=2309405360176655368265
weibo.com/ttarticle/p/show?comment=1&id=2309405360176483401970
weibo.com/ttarticle/p/show?comment=1&id=2309405360176655368265
weibo.com/ttarticle/p/show?comment=1&id=2309405360176814489774
weibo.com/ttarticle/p/show?id=2309405360176814489774
weibo.com/ttarticle/p/show?id=2309405360178269913157
weibo.com/ttarticle/p/show?comment=1&id=2309405360178269913157
weibo.com/ttarticle/p/show?id=2309405360178429296865
weibo.com/ttarticle/p/show?comment=1&id=2309405360178429296865
weibo.com/ttarticle/p/show?comment=1&id=2309405360178593136763
weibo.com/ttarticle/p/show?id=2309405360178593136763
weibo.com/ttarticle/p/show?id=2309405360178752258297
weibo.com/ttarticle/p/show?comment=1&id=2309405360178752258297
weibo.com/ttarticle/p/show?id=2309405360178916098189
weibo.com/ttarticle/p/show?comment=1&id=2309405360178916098189
weibo.com/ttarticle/p/show?id=2309405360179092258876
weibo.com/ttarticle/p/show?comment=1&id=2309405360179092258876
weibo.com/ttarticle/p/show?id=2309405360179255574621
weibo.com/ttarticle/p/show?comment=1&id=2309405360179255574621
weibo.com/ttarticle/p/show?id=2309405360179415220553
weibo.com/ttarticle/p/show?comment=1&id=2309405360179415220553
weibo.com/ttarticle/p/show?id=2309405360179582992662
weibo.com/ttarticle/p/show?comment=1&id=2309405360179582992662
weibo.com/ttarticle/p/show?id=2309405360179750502533
weibo.com/ttarticle/p/show?comment=1&id=2309405360179750502533
weibo.com/ttarticle/p/show?id=2309405360179918274693
weibo.com/ttarticle/p/show?comment=1&id=2309405360179918274693
weibo.com/ttarticle/p/show?id=2309405360180081852523
weibo.com/ttarticle/p/show?comment=1&id=2309405360180081852523
weibo.com/ttarticle/p/show?id=2309405360180241498273
weibo.com/ttarticle/p/show?comment=1&id=2309405360180241498273
weibo.com/ttarticle/p/show?id=2309405360180404813971
weibo.com/ttarticle/p/show?comment=1&id=2309405360180404813971
weibo.com/ttarticle/p/show?comment=1&id=2309405360180568391705
weibo.com/ttarticle/p/show?id=2309405360180568391705
weibo.com/ttarticle/p/show?id=2309405360180736426143
weibo.com/ttarticle/p/show?id=2309405360180904198437
weibo.com/ttarticle/p/show?comment=1&id=2309405360180736426143
weibo.com/ttarticle/p/show?comment=1&id=2309405360180904198437
weibo.com/ttarticle/p/show?id=2309405360181071708229
weibo.com/ttarticle/p/show?comment=1&id=2309405360181071708229
weibo.com/ttarticle/p/show?id=2309405360181231092014
weibo.com/ttarticle/p/show?comment=1&id=2309405360181231092014
weibo.com/ttarticle/p/show?id=2309405360181394931930
weibo.com/ttarticle/p/show?comment=1&id=2309405360181394931930
weibo.com/ttarticle/p/show?comment=1&id=2309405360181566898182
weibo.com/ttarticle/p/show?id=2309405360181566898182
weibo.com/ttarticle/p/show?id=2309405360181730476046
weibo.com/ttarticle/p/show?comment=1&id=2309405360181730476046
weibo.com/ttarticle/p/show?id=2309405360181889859790
weibo.com/ttarticle/p/show?comment=1&id=2309405360181889859790
weibo.com/ttarticle/p/show?id=2309405360182053437483
weibo.com/ttarticle/p/show?comment=1&id=2309405360182053437483
weibo.com/ttarticle/p/show?id=2309405360182217015383
weibo.com/ttarticle/p/show?comment=1&id=2309405360182217015383
weibo.com/ttarticle/p/show?id=2309405360182384787620
weibo.com/ttarticle/p/show?comment=1&id=2309405360182384787620
weibo.com/ttarticle/p/show?comment=1&id=2309405360182741303438
weibo.com/ttarticle/p/show?id=2309405360182741303438
weibo.com/ttarticle/p/show?id=2309405360182908813405
weibo.com/ttarticle/p/show?comment=1&id=2309405360182908813405
weibo.com/ttarticle/p/show?id=2309405360183068197238
weibo.com/ttarticle/p/show?comment=1&id=2309405360183068197238
weibo.com/ttarticle/p/show?id=2309405360183231774781
weibo.com/ttarticle/p/show?comment=1&id=2309405360183231774781
weibo.com/ttarticle/p/show?id=2309405360184112578596
weibo.com/ttarticle/p/show?comment=1&id=2309405360184112578596
weibo.com/ttarticle/p/show?id=2309405360184272224610
weibo.com/ttarticle/p/show?comment=1&id=2309405360184272224610
weibo.com/ttarticle/p/show?id=2309405360184435540201
weibo.com/ttarticle/p/show?comment=1&id=2309405360184435540201
weibo.com/ttarticle/p/show?id=2309405360184594923779
weibo.com/ttarticle/p/show?comment=1&id=2309405360184594923779
weibo.com/ttarticle/p/show?id=2309405360184976605302
weibo.com/ttarticle/p/show?comment=1&id=2309405360184976605302
weibo.com/ttarticle/p/show?id=2309405360185140183492
weibo.com/ttarticle/p/show?comment=1&id=2309405360185140183492
weibo.com/ttarticle/p/show?id=2309405360185304023196
weibo.com/ttarticle/p/show?comment=1&id=2309405360185304023196
weibo.com/ttarticle/p/show?id=2309405360185467338777
weibo.com/ttarticle/p/show?comment=1&id=2309405360185467338777
weibo.com/ttarticle/p/show?id=2309405360185626722611
weibo.com/ttarticle/p/show?comment=1&id=2309405360185626722611
