标题: 关于联想M4400 M4450笔记本电池报错问题 不充电屏幕显示The battery installed is ... [打印本页] 作者: 鑫晖科技 时间: 2018-3-29 10:17 标题: 关于联想M4400 M4450笔记本电池报错问题 不充电屏幕显示The battery installed is ... 联想M4400和M4450这个系列的机子,很难配上合适的电池问题,开机屏幕提示:The battery installed is not supported by this system and will not charge. Please replace the battery with the correct Lenovo battery for this system. Press the ESC key to continue
