ZXCVWtest
查看: 2103|回复: 12
如果评价2017苹果发布会Face ID的解锁失败?
发表于 2017-11-4 14:43:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
发表于 2017-11-4 14:43:10 | 只看该作者 �
官方回复:
"People were handling the device for stage demo ahead of time," says a rep, "and didn't realize Face ID was trying to authenticate their face. After failing a number of times, because they weren't Craig, the iPhone did what it was designed to do, which was to require his passcode." In other words, "Face ID worked as it was designed to."
和我猜测的一样,有工作人员布置样机的时候,那台 iPhone 多次试图识别人脸,但是因为工作人员的面部信息显然不对,识别次数超限,就和尝试错误指纹错误次数过多一样,因此要求输入密码。Face ID 按照设计意图工作正常。
来源:http://iphone.appleinsider.com/articles/17/09/14/apple-denies-claims-iphone-x-failed-in-onstage-demo-says-face-id-feature-worked-as-designed
9月15日分割线
今天这个问题基本上可以盖棺定论了。Face ID本身没问题,第一台手机解锁失败是由于有人拿了这部手机。在不经意间导致两次识别错误后当Craig再次拿起手机时必须输入密码。
此前本问题描述为是否“翻车”,对于这个词居然可能有三种歧义,Face ID有问题,没解锁成功——翻车;Face ID没问题,没解锁成功——翻车;Face ID没问题,第一次解锁不成功,第二次解锁成功——没翻车。在修改了题目描述后,这个问题就很明朗了。
这个问题不会有很多人关注,但是我依然要回答以正视听。
第一点:Craig手里有两个手机,第一次解锁失败,后放下手机。然后拿起第二个手机,第二次解锁成功。
第二点:Your passcode is required to enable Touch ID ····大家可自己对照看下手机的Touch ID失败时的提示“Try Again”,此类只会出现很久没使用的情况下。(更新:一直不息屏下,多次识别失败后也会出现)
最后,孰是孰非,大家自己判断吧。Face ID一定是不完善的一代,就像Touch ID在5s上的体验。
这岂不是说明以后只要有人看两眼你的手机,你就不得不用密码解锁了?
Sep. 13th 2017 updated 来自“9to5mac”的消息
Apple正式对发布会上的意外进行说明。以下是来自Apple代表的声明。
People were handling the device for stage demo ahead of time,” says a rep, “and didn’t realize Face ID was trying to authenticate their face. After failing a number of times, because they weren’t Craig, the iPhone did what it was designed to do, which was to require his passcode.” In other words, “Face ID worked as it was designed to.”
Apple代表表示,在发布会演示环节之前,用于演示的iPhone被多人在他们不知情的情况下“注视”,进而多次触发了face ID的判定功能。然而,这台演示机只录入了Craig的面容信息,所以之前的多次“注视”均视为失败的解锁尝试。根据iPhone的安全保护程序,多次失败后会要求用户输入密码。换言之,face ID只是按其既定的程序运行而已,这个失败不属于face ID。
原答案:
很不应该!
失败的原因有:1. 手机刚刚重启过;2.手机闲置时间太久。这两个原因都会导致touch/face ID被禁用。
但作为一个Apple leader,并且在发布会的场合,连这个自己设计的细节都没有考虑到真的是很让人为Apple捏一把汗啊。
但是,话说回来,这个小插曲并不能直接说face ID本身不好用。只能说Apple真的没有准备的很充分。
来来来,我是来给Craig洗白的
从ios9开始,如果超过六天没用过passcode解锁,8小时内没用过touch id系统会自动禁用touch id,face id应该也是同理,注意看当时的视频,屏幕显示的是“Your passcode is required to enable Face ID”,可以推理出是face id被禁用,失败的话会显示“Try Again”
我相信很多朋友都遇到过,某天起床会突然让你用passcode解锁
解锁失败后提示:请输入密码来启动Face ID。
所以并不是Face ID不可靠,而是他忘记是刚开机,需要激活Face ID。
算是一个小失误。但对于一向以精细著称的苹果发布会来说,真是一个不该犯的错误。
是之前后台工作人员错误解锁手机太多次(想象某个员工拿起来亮屏看了看手机,此时就会触发一次错误解锁)然后导致保护机制启动手机锁定face id造成的,不是face id的锅。
不是什么重启,重启的提示不是视频那样,更不是什么解锁错误,解锁错误会弹出try again之类的提示以及那把小锁会抖动,这些视频中都不存在。
同志们看看第一的答案再强答好吗?或者你们根本没有iPhone 就是想黑一下?
头像被屏蔽
10#
第一次使用需要密码
苹果公布调查结果,这是一位员工在演示前重启了手机,而忘记输入密码启用 Face ID,就像 Touch ID 一样,每次重启手机都要输入密码以启用 Touch ID。
而从界面提示上来看,提示的是「输入密码以启用 Face ID」,如果是识别不了,应该类似Touch ID 一样,请重新尝试,并在多次失败失败,弹出输入密码。
所以我相信苹果说的,这不是技术问题,而是失误,我们应该相信 Face ID。
这些都是在有光源的情况下,如果光源缺失呢?
不是的。。他其实总共试了三次。。第一次看手机,没反应;关了再看,弹出需要密码(苹果的解释是工作人员使用时,苹果多次识别导致出现识别失败因为不是Craig本人。。。意思就是,手机放在那里有人多看两眼你就要输密码啦。。)第三次,换了一部手机再看,终于成功了。。。。一个功能的第一次公众演示就失败,从概率角度来说,那就是有点大了。。
---------------------------------------Update: 苹果解释的是第二次,出现提示输入密码的时候,忽略了Craig第一次解锁没成功摁掉重来的情况。。。他说Let's try that again...
