- 积分
- 50
- 下载分
- 分
- 威望
- 点
- 原创币
- 点
- 下载
- 次
- 上传
- 次
- 注册时间
- 2008-7-2
- 精华
以下是R3测的结果。
R3MEMID version 1.07, (c) Copyright ATI Technologies Inc, 2003
Log file generation enabled to .\R3MEMID.LOG ...
Extended logging enabled ...
Reference data file (RDF) loading disabled ...
Failing bits in test [1] Fill
errcount: 8388352
MDB0: 58
Failing bits in test [2] Data line toggle (GUI)
errcount: 4193792
MDB0: 58
Failing bits in test [3] RW page (GUI)
errcount: 4194176
MDB0: 58
Failing bits in test [4] RW channel (GUI)
errcount: 4194176
MDB0: 58
Failing bits in test [5] Data mask
errcount: 4194176
MDB0: 58
Failing bits in test [7] Byte swap macro+micro8x2 read
errcount: 37748385
MDA0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
MDB0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
Failing bits in test [8] HOST_DATA/<f,b>/M2L
errcount: 15040
MDB0: 58
errcount: 4163
MDB0: 58
errcount: 30081
MDB0: 58
errcount: 23364
MDB0: 58
errcount: 6633
MDB0: 58
errcount: 46853
MDB0: 58
errcount: 39858
MDA0: 41 42 43 44 45 46 47
MDB0: 41 42 43 44 45 46 47 58
errcount: 14827
MDA0: 40 41 42 43 44 45 46 47
MDB0: 40 41 42 43 44 45 46 47 58
errcount: 78476
Failing bits in test [9] Line slopes/dir/P/solid
errcount: 18321
MDB0: 58
errcount: 948
MDB0: 58
errcount: 36649
MDB0: 58
errcount: 28806
MDB0: 58
errcount: 1236
MDB0: 58
errcount: 57596
MDB0: 58
errcount: 48028
MDA0: 40 41 42 43 44 45 47
errcount: 6045
errcount: 95193
MDB0: 58
TEST RESULT SUMMARY:
Rv350 (0x4150) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1 ] Fill : FAIL
Error ID 0VB001
1024 x 768 - 32 bpp ( 60 Hz): TEST FAILURE
failing bit : MDB0 58
[2 ] Data line toggle (GUI) : FAIL
Error ID 0VB023
[3 ] RW page (GUI) : FAIL
Error ID 0VB025
[4 ] RW channel (GUI) : FAIL
Error ID 0VB028
[5 ] Data mask : FAIL
Error ID 0VB006
[6 ] Macro + Micro8x2 tiling read : PASS
[7 ] Byte swap macro+micro8x2 read : FAIL
Error ID 0VC018
failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 0 1 2 3 4 5 6 7 ...
[8 ] HOST_DATA/<f,b>/M2L : FAIL
Error ID 0TR014
640 x 480 - 8 bpp ( 75 Hz): TEST FAILURE
640 x 480 - 15 bpp ( 75 Hz): TEST FAILURE
640 x 480 - 16 bpp ( 75 Hz): TEST FAILURE
640 x 480 - 32 bpp ( 75 Hz): TEST PASSED
800 x 600 - 8 bpp ( 75 Hz): TEST FAILURE
800 x 600 - 15 bpp ( 75 Hz): TEST FAILURE
800 x 600 - 16 bpp ( 75 Hz): TEST FAILURE
800 x 600 - 32 bpp ( 75 Hz): TEST PASSED
1024 x 768 - 8 bpp ( 75 Hz): TEST FAILURE
failing bit : MDA0 41 42 43 44 45 46 47 MDB0 41 42 43 44 45 46 47 58
1024 x 768 - 15 bpp ( 75 Hz): TEST FAILURE
failing bit : MDA0 40 41 42 43 44 45 46 47 MDB0 40 41 42 43 44 45 46 47 ...
1024 x 768 - 16 bpp ( 75 Hz): TEST FAILURE
1024 x 768 - 32 bpp ( 75 Hz): TEST PASSED
[9 ] Line slopes/dir/P/solid : FAIL
Error ID 0TR010
failing bit : MDA0 40 41 42 43 44 45 47 MDB0 40 41 42 43 44 45 46 47 ...
1024 x 768 - 32 bpp ( 75 Hz): TEST PASSED |
