- 积分
- 70
- 下载分
- 分
- 威望
- 点
- 原创币
- 点
- 下载
- 次
- 上传
- 次
- 注册时间
- 2009-8-30
- 精华
我将添加所有系统框图。我希望这将有助确定谁是谁,前您开始下载文件
I will add all system block diagrams, if available or an information about system components.
I hope it will help to identify who is who, before you start to download a file.
[img]
[/img]
[img]
[/img]
Mitac 7068 Schematics R01
PRODUCT CODE 6702
PROJECT CODE 784
PCB 316670200003
~No Block Diagram available (没有框图)~
CPU -Intel mPGA2 Pentium III/Celeron
North Bridge - VT8603 with S3 Savage4 AGPx4
South Bridge - VT8231
Card Bus controller - PCI1410 (OZ6812)
IEEE1394 -UPD72872
CLOCK SYNTHERISZER- ICS9248-101
RAM Type - SDRAM
AC97 Codec- CS4299
AUDIO AMPLIFIER - TPA0202
LAN - LSI80227
CPU_CORE/+2.5V/VTT - MAX1711
+3V/+5V/+12V - MAX1632
Mitac 7068T Schematic R0B
PRODUCT CODE : 6726
PROJECT CODE : G009
PCB 41167260001
CPU -Intel TUALATIN BGA PGA479
Card Bus controller - PCI1410 (CB1410)
IEEE1394 -UPD72872
CLOCK SYNTHERISZER- ICS950602
RAM Type - SDRAM
AUDIO Codec- ALC201
LAN - LSI80227
CPU_CORE/+2.5V/VTT - MAX1718
+3V/+5V/+12V - MAX1632 |
