- 积分
- 7
- 下载分
- 分
- 威望
- 点
- 原创币
- 点
- 下载
- 次
- 上传
- 次
- 注册时间
- 2009-8-3
- 精华
You were right, problem is in south bridge. HP uses 2 PINs on SB CHIP (free ports that are usualy used for USB) to generate CDRESET and HDDRESET. I saw some other laptops that are generating HDDRESET directly from PCIRESET. I will try to do some workaround in order not to replace south bridge chip. I will try to put the PIN 1 of IC U83 on the +3V level and try to use only PCIRST# to reset hard drive.
I let you know if it worked.
你是正确的,问题是在SB。
HP使用2引脚SB芯片(自由港通常用于USB接口)生成CDRESET和HDDRESET 。
我看到一些其他的笔记本电脑,正在创造HDDRESET直接从PCIRESET 。
我会尝试做一些方法,以便不更换南桥芯片。
我将努力把PIN1的IC U83的+3V级,并尝试仅使用PCIRST #重置硬盘驱动器。
我让你知道,如果它的工作。 |
