Report Date | 2021-03-10 00:29:57 |
Generated by | MemTest86 V10.6 Free (64-bit) Visit MemTest86.com to Upgrade to Pro |
Result | FAIL |
EFI Specifications | 2.70 |
System | |
Manufacturer | ASUSTeK COMPUTER INC. |
Product Name | ZenBook UX433FN_UX433FN |
Version | 1.0 |
Serial Number | JCN0CV09P025514 |
BIOS | |
Vendor | American Megatrends Inc. |
Version | UX433FN.311 |
Release Date | 03/10/2021 |
Baseboard | |
Product Name | UX433FN |
Version | 1.0 |
Serial Number | N0CV1849MB0124888 |
CPU Type | Intel Core i7-8565U @ 1.80GHz |
CPU Clock | 1902 MHz [Turbo: 4026.0 MHz] |
# Logical Processors | 8 (4 enabled for testing) |
L1 Cache | 4 x 64K (227729 MB/s) |
L2 Cache | 4 x 256K (99224 MB/s) |
L3 Cache | 8192K (48227 MB/s) |
Memory | 16205M (12191 MB/s) |
RAM Configuration | LPDDR3 2133MT/s / 1.200V |
Number of RAM SPDs detected | 0 |
Number of RAM slots | 2 |
Number of RAM modules | 2 |
ChannelA-DIMM0 | 8GB LPDDR3 2Rx8 PC3-17000 |
Vendor Part Info | Micron / MT52L1G32D4PG-093 / 00000000 |
SMBIOS Profile | 2133MT/s 1.2V |
ChannelB-DIMM0 | 8GB LPDDR3 2Rx8 PC3-17000 |
Test Start Time | 2021-03-10 00:20:52 |
Elapsed Time | 0:03:00 |
Memory Range Tested | 0x0 - 46E000000 (18144MB) |
CPU Selection Mode | Parallel (All CPUs) |
CPU Temperature Min/Max/Ave | 68C/77C/71C |
# Tests Completed | 6/48 (12%) |
# Tests Passed | 6/6 (100%) |
Lowest Error Address | 0x4100010 (65MB) |
Highest Error Address | 0x4750C50 (71MB) |
Bits in Error Mask | 0000000000000008 |
Bits in Error | 1 |
Max Contiguous Errors | 1 |
CPUs that detected memory errors | { 4 } |
. | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | x | . | . | . |
63 | 0 |
Test | # Tests Passed | Errors |
Test 0 [Address test, walking ones, 1 CPU] | 1/1 (100%) | 0 |
Test 1 [Address test, own address, 1 CPU] | 1/1 (100%) | 0 |
Test 2 [Address test, own address] | 1/1 (100%) | 0 |
Test 3 [Moving inversions, ones & zeroes] | 1/1 (100%) | 0 |
Test 4 [Moving inversions, 8-bit pattern] | 1/1 (100%) | 0 |
Test 5 [Moving inversions, random pattern] | 1/1 (100%) | 0 |
Test 6 [Block move, 64-byte blocks] | 0/0 (0%) | 10000 |
Test 7 [Moving inversions, 32-bit pattern] | 0/0 (0%) | 0 |
Test 8 [Random number sequence] | 0/0 (0%) | 0 |
Test 9 [Modulo 20, ones & zeros] | 0/0 (0%) | 0 |
Test 10 [Bit fade test, 2 patterns, 1 CPU] | 0/0 (0%) | 0 |
Test 13 [Hammer test] | 0/0 (0%) | 0 |
Last 10 Errors |
2021-03-10 00:23:51 - [Data Error] Test: 6, CPU: 4, Address: 4750C50, Expected: 00000018, Actual: 00000010 |
2021-03-10 00:23:51 - [Data Error] Test: 6, CPU: 4, Address: 4750C30, Expected: FFFFFFE7, Actual: FFFFFFEF |
2021-03-10 00:23:51 - [Data Error] Test: 6, CPU: 4, Address: 4750C10, Expected: 00000000, Actual: 00000008 |
2021-03-10 00:23:51 - [Data Error] Test: 6, CPU: 4, Address: 4750BF0, Expected: FFFFFFFF, Actual: FFFFFFF7 |
2021-03-10 00:23:51 - [Data Error] Test: 6, CPU: 4, Address: 4750410, Expected: 00000018, Actual: 00000010 |
2021-03-10 00:23:51 - [Data Error] Test: 6, CPU: 4, Address: 47503D0, Expected: 00000000, Actual: 00000008 |
2021-03-10 00:23:51 - [Data Error] Test: 6, CPU: 4, Address: 47503B0, Expected: FFFFFFFF, Actual: FFFFFFF7 |
2021-03-10 00:23:51 - [Data Error] Test: 6, CPU: 4, Address: 474FBD0, Expected: 00000018, Actual: 00000010 |
2021-03-10 00:23:51 - [Data Error] Test: 6, CPU: 4, Address: 474FBB0, Expected: FFFFFFE7, Actual: FFFFFFEF |
2021-03-10 00:23:51 - [Data Error] Test: 6, CPU: 4, Address: 474FB90, Expected: 00000000, Actual: 00000008 |
This document certifies that the Tests described above have been carried out by a suitably qualified technician on the System described above. |
wzbCM 发表于 2024-2-8 18:59
内存块移动方式来进行压力测试
Test 6
欢迎光临 迅维网 (https://www.chinafix.com/) | Powered by Discuz! X3.4 |
