查看: 1465|回复: 1
[内存维修]
Need Help
发表于 2014-7-8 19:57:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
How to use RST pro usb software and which tool is needed to run this software
发表于 2014-7-9 20:33:04 | 只看该作者 �
POOR SON, YOU NEED WINHEX  WRITE THE RST IMG 。IF you fail, you may add my qq . I CAN HELP YOU REMOT...
