查看: 3746|回复: 4
[显卡维修]
X800GTO 花屏求帮分析...
发表于 2012-8-4 10:06:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
各位大师,自用的一个X800GTO某天开机突然就花屏了,在DOS下很多横条,勉强能看见部分字符,用R3MEMID查了一下,log是:
R3MEMID version 1.13, (c) Copyright ATI Technologies Inc, 2004
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
TEST RESULT SUMMARY:
R420/M18 (0x4a49) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID G0VB001
  1024 x  768 - 16 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDD0 4 5 9 15 19 21 22 23 ...
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID G0VB023
    failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 0 1 2 3 4 5 6 7 ... MDC0 0 1 2 3 4 5 6 7 ... MDD0 0
[3  ] RW column (GUI)                                     : FAIL
    Error ID G0VB024
    failing bit : MDD0 0 1 2 3 4 5 6 7 ...
[4  ] RW page (GUI)                                       : FAIL
    Error ID G0VB025
    failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 0 1 2 3 4 5 6 7 ... MDD0 0 1 2 3 4 5 6 7 ...
[5  ] RW channel (GUI)                                    : FAIL
    Error ID G0VB028
[6  ] Data mask                                           : FAIL
    Error ID G0VB006
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
[7  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID G0VC006
[8  ] Macro + Micro4x4 tiling write                       : FAIL
    Error ID G0VC009
[9  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID G0VC018
[10 ] Byte swap macro+micro4x4 write                      : FAIL
    Error ID G0VC021
[11 ] Marco+Micro8x2 alignment write                      : FAIL
    Error ID G0VC052
[12 ] Macro+Micro4x4 alignment read                       : FAIL
    Error ID G0VC057
    failing bit : MDA0 0 1 2 3 4 5 6 8 ... MDB0 0 1 2 3 4 5 6 7 ... MDC0 0 1 2 3 4 5 6 8 ... MDD0 0
[13 ] Movblit, 4 align, T                                 : FAIL
    Error ID G0TR055
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.13 not found
[14 ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID G0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R051A.14 not found
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R052A.14 not found
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R053A.14 not found
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R055A.14 not found
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R061A.14 not found
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R062A.14 not found
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R063A.14 not found
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R065A.14 not found
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R071A.14 not found
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R072A.14 not found
     error : R073A.14 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R075A.14 not found
[15 ] Line slopes/dir/P/solid                             : FAIL
    Error ID G0TR010
     error : R051A.15 not found
     error : R052A.15 not found
     error : R053A.15 not found
     error : R055A.15 not found
     error : R061A.15 not found
     error : R062A.15 not found
     error : R063A.15 not found
     error : R065A.15 not found
     error : R071A.15 not found
     error : R072A.15 not found
     error : R073A.15 not found
     error : R075A.15 not found
Failure detected.
查看了下论坛的贴子,说是排阻容易坏,但是测量了所有内存旁的排阻,都是正常的.麻烦各位大师帮看看该查哪里?
发表于 2012-8-4 12:43:11 | 只看该作者 �
我也有一块花屏X800
发表于 2012-8-4 18:26:24 | 只看该作者 �
用什么测得啊,没有主要数据呢???
看不懂就说看不懂,这么多数据位报错,还要什么数据?  发表于 2012-8-4 19:03
受到警告 4#
发表于 2012-8-5 17:49:38 | 只看该作者 �
这么乱的东东怎么测呀
发表于 2012-8-10 11:06:42 | 只看该作者 �
已经修好了,刚开始按R3的LOG加焊显存D区0-31,故障依旧,然后百度了下说R3有规律报错估计是GPU有问题,于是又加焊GPU,还是一样,最后只有使用笨方法,每块显存加焊一次,最后在加焊B区32-64时故障消失,但是使用10分钟左右故障又出现..最后拆下重新植球重焊.故障修复 .重新用R3 1.13测试,发现还是一堆上面的错误,最后好不容易找到一块一模一样的好显卡,用R3测试也是上面的错误.估计是R3memid不能正确识别...
