查看: 7870|回复: 16
HP图纸对应表
发表于 2011-7-6 16:16:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
HP图纸对应表.zip (11.84 KB, 下载次数: 84)
参与人数 1下载分 +20 收起 理由
无边思绪 + 20 ..
发表于 2011-7-6 16:17:30 | 只看该作者 �
Luke  2.0=JIXI        Luke 2.x        TouchSmart tm2        DSC         PCAA71        12.1"        RP/ALU
        Luke 2.x        TouchSmart tm2        UMA         PCAA72        12.1"        RP/ALU
        Luke 2.x        TouchSmart tm2        DSC         PCAA73        12.1"        RP/ALU
        Luke 2.x        TouchSmart tm2        UMA         PCAA74        12.1"        RP/ALU
        Luke 2.x        TouchSmart tm2        DSC         PCAA75        12.1"        RP/ALU
        Luke 2.x        TouchSmart tm2        UMA        PCAA76        12.1"        RP/ALU
        Luke 2.x        TouchSmart tm2        DSC        PCAA77        12.1"        RP/ALU
        Luke 2.x        TouchSmart tm2        UMA        PCAA78        12.1"        RP/ALU
        Luke 2.x        TouchSmart tm2        DSC        PCAA79        12.1"        RP/ALU
        Luke 2.x        TouchSmart tm2        DSC        PCAA82        12.1"        RP/ALU
        Luke 2.x        TouchSmart tm2        UMA        PCAA83        12.1"        RP/ALU
        Luke 2.x        TouchSmart tm2        DSC        PCAA84        12.1"        RP/ALU
DT 10        Diesel 1.0        HP ProBook 6450b        UMA HM57 i5-520M        PC3941        14"
        Diesel 1.0        HP ProBook 6450b        UMA WWAN HM57 i5-520M        PC3942        14"
        Diesel 1.0        HP ProBook 6450b        UMA WANvPro QM57 i5-540M        PC3943        14"
        Diesel 1.0        HP ProBook 6450b        DSC HM57 i5-520M        PC3944        14"
        Diesel 1.0        HP ProBook 6450b        DSC WWAN HM57        PC3945        14"
        Diesel 1.0        HP ProBook 6450b        DSCWANvProQM57 i7-620M        PC3946        14"
        Diesel 1.0        HP ProBook 6550b        UMA HM57 i5-520M        PC3971        15.6"
        Diesel 1.0        HP ProBook 6550b        UMA WWAN HM57 i5-520M        PC3972        15.6"
        Diesel 1.0        HP ProBook 6550b        UMAWANvProQM57 i5-520M        PC3973        15.6"
        Diesel 1.0        HP ProBook 6550b        DSC HM57 i5-520M        PC3974        15.6"
        Diesel 1.0        HP ProBook 6550b        DSC WWAN HM57 i5-540M        PC3975        15.6"
        Diesel 1.0        HP ProBook 6550b        DSCWANvProQM57 i7-720M        PC3976        15.6"
        TIMEX 1.x        HP ProBook 6455b        N620        PC3731        14"
        TIMEX 1.x        HP ProBook 6455b        WWAN N830        PC3732        14"
        TIMEX 1.x        HP ProBook 6455b        N620        PC3741        15.6"
        TIMEX 1.x        HP ProBook 6455b        WWAN N930        PC3742        15.6"
VV 10        Villemont 1.X        Compaq 320        UMA GL40        PCAF51        13.3"        BLK
        Villemont 1.X        Compaq 320        UMA GM45        PCAF52        13.3"        BLK
        Villemont 1.X        Compaq 321        DSC PM45        PCAF53        13.3"        BLK
        Villemont 1.X        Compaq 420        UMA GML40        PCAF54        14.0"        BLK
        Villemont 1.X        Compaq 420        UMA GM45        PCAF55        14.0"        BLK
        Villemont 1.X        Compaq 421        DSC PM45        PCAF56        14.0"        BLK
        Villemont 1.X        Compaq 620        UMA GL40        PCAF57        15.6"        BLK
        Villemont 1.X        Compaq 620        UMA GM45        PCAF58        15.6"        BLK
        Villemont 1.X        Compaq 621        DSC PM45        PCAF59        15.6"        BLK
        Villemont 1.X        Compaq 320        UMA GL40        PCAF60        13.3"        BLK
        Valima 1.X        HP 425        UMA RS880MN        PCAF61        14.0"        GRY
        Valima 1.X        HP 625        UMA RS880MN        PCAF62        15.6"        GRY
        Valima 1.X        HP 625        UMA RS880MN        PCAF63        15.6"        GRY
        Villemont 1.X        Compaq 320        UMA GM45        PCAF71        13.3"        BLK
        Villemont 1.X        Compaq 321        DSC PM45        PCAF72        13.3"        BLK
        Villemont 1.X        Compaq 320        UMA GL40        PCAF73        13.3"        BLK
        Villemont 1.X        Compaq 320        UMA GM45        PCAF74        13.3"        BLK
        Villemont 1.X        Compaq 321        DSC PM45        PCAF75        13.3"        BLK
        Valima 1.X        Compaq 325        UMA RS880        PCAF81        13.3"        BLK
        Valima 1.X        Compaq 326        DSC RS880        PCAF82        13.3"        RED
        Valima 1.X        Compaq 325        UMA RS880        PCAF83        13.3"        BLK
        Valima 1.X        Compaq 326        DSC RS880        PCAF84        13.3"        RED
        Valima 1.X        Compaq 325        UMA RS880        PCAF85        13.3"        BLK
        Valima 1.X        Compaq 326        DSC RS880        PCAF86        13.3"        BLK
        Villemont 1.X        HP 420        UMA GL40        PCAF91        14.0"        GRY
        Villemont 1.X        HP 420        UMA GM45        PCAF92        14.0"        GRY
        Villemont 1.X        HP 620        UMA GL40        PCAF93        15.6"        GRY
        Villemont 1.X        HP 620        UMA GM45        PCAF94        15.6"        GRY
        Villemont 1.X        HP 620        UMA GL40        PCAF95        15.6"        GRY
        Villemont 1.X        HP 620        UMA GM45        PCAF96        15.6"        GRY
Luke=JIXI        Luke 1.x        TouchSmart tm2        DSC C2D SU9600        PCAA23        12.1"        RP/ALU
        Luke 1.x        TouchSmart tm2        UMA C2D SU7300        PCAA31        12.1"        RP/ALU
        Luke 1.x        TouchSmart tm2        DSC C2D SU7300        PCAA33        12.1"        RP/ALU
        Luke 1.x        TouchSmart tm2        UMA Pent SU4100        PCAA41        12.1"        RP/ALU
        Luke 1.x        TouchSmart tm2        DSC Pent SU4100        PCAA43        12.1"        RP/ALU
        Luke 1.x        TouchSmart tm2        UMA Cel SU2300        PCAA51        12.1"        RP/ALU
VV 09        Vulcain 1.X        Compaq 510        UMA GLE960        PCAF01        14"        BLK
        Vulcain 1.X        Compaq 510        UMA GME965        PCAF02        14"
        Vulcain 1.X        Compaq 511        DSC PM965        PCAF06        14"        BLK
        Vulcain 1.X        Compaq 511        DSC PM965        PCAF10        14"
        Vulcain 1.X        Compaq 610        UMA GLE960        PCAF13        15.6"        BLK
        Vulcain 1.X        Compaq 610        UMA GME965        PCAF14        15.6"        BLK
        Vulcain 1.X        Compaq 610        DSC PM965        PCAF16        15.6"        BLK
        Volna 1.X        Compaq 515        UMA RS780MN        PCAF21        14"        GREY
        Volna 1.X        Compaq 516        DSC RX781        PCAF26        14"        BLK
        Volna 1.X        Compaq 515        UMA RS780MN        PCAF29        14"        BLK
        Volna 1.X        Compaq 615        UMA RS780MN        PCAF31        15.6"        BLK
                                                BLK
SS 09        Zenith 1.0        ProBook 4410s        GL40 UMA        PCAC31        14"        BLK
        Zenith 1.0        ProBook 4410s        GM45 UMA         PCAC32        14"        GREY
        Zenith 1.0        ProBook 4410s        GL40 UMA         PCAC33        14"        BLK
        Zenith 1.0        ProBook 4410s        GM45 UMA        PCAC34        14"
        Zenith 1.0        ProBook 4411s        PM45 DSC        PCAC36        14"        BLK
        Zenith 1.0        ProBook 4411s        PM45 DSC        PCAC37        14"        BLK
        Zenith 1.0        HP ProBook 4510s        PM45 DDR3 WWAN        PCAC40        15.6"        RED
        Zenith 1.0        ProBook 4510s        GL40 UMA        PCAC41        15.6"        RED
        Zenith 1.0        ProBook 4510s        GM45 UMA        PCAC42        15.6"        BLK
        Zenith 1.0        ProBook 4510s        GL40 UMA        PCAC43        15.6"        RED
        Zenith 1.0        ProBook 4510s        GM45 UMA        PCAC45        15.6"        BLK
        Zenith 1.0        ProBook 4510s        PM45 DSC        PCAC46        15.6"        BLK
        Zenith 1.0        ProBook 4510s        PM45 DSC        PCAC47        15.6"        BLK
        Zenith 1.0        ProBook 4510s        GM45 WWAN         PCAC52        15.6"        RED
        Zenith 1.0        ProBook 4510s        GM45 WWAN        PCAC54        15.6"        RED
        Zenith 1.0        ProBook 4510s        PM45 WWAN        PCAC56        15.6"        BLK
        Zenith 1.0        ProBook 4510s        PM45 WWAN        PCAC57        15.6"        RED
        Zenith 1.0        ProBook 4410s        GL40 DDR3        PCAC58        14"        BLK
        Zenith 1.0        HP ProBook 4410s        GM45 DDR3        PCAC60        14"        RED
        Zenith 1.0        HP ProBook 4410s        GM45 DDR3        PCAC61        14"        BLK
        Zenith 1.0        HP ProBook 4411s        PM45 DDR3        PCAC62        14"        RED
        Zenith 1.0        HP ProBook 4411s        PM45 DDR3        PCAC63        14"        BLK
        Zenith 1.0        HP ProBook 4410s        GM45 DDR3 WWAN        PCAC66        14"        BLK
        Zenith 1.0        HP ProBook 4411s        PM45 DDR3 WWAN        PCAC68        14"        RED
        Zenith 1.0        HP ProBook 4510s        GL40 DDR3        PCAC70        15.6"        BLK
        Zenith 1.0        HP ProBook 4510s        GM45 DDR3        PCAC72        15.6"        RED
        Zenith 1.0        HP ProBook 4510s        GM45 DDR3         PCAC73        15.6"        BLK
        Zenith 1.0        HP ProBook 4510s        PM45 DDR3        PCAC74        15.6"        BLK
        Zenith 1.0        HP ProBook 4510s        PM45 DDR3        PCAC75        15.6"        BLK
        Zenith 1.0        HP ProBook 4510s        GM45 DDR3 WWAN        PCAC79        15.6"        BLK
        Invicta 1.X        ProBook 4710s        PM45 DSC        PCAC05        17.3"        BLK
        Invicta 1.X        ProBook 4710s        PM45 DSC DDR3        PCAC06        17.3"        BLK
        Piaget 1.x        ProBook 4415s        RS780MN UMA        PCAC13        14"        RED
        Piaget 1.x        ProBook 4415s        RS780MN UMA        PCAC14        14"        RED
        Piaget 1.x        ProBook 4416s        RX781 DSC        PCAC16        14"        BLK
        Piaget 1.x        ProBook 4416s        RX781 DSC        PCAC17        14"        BLK
        Piaget 1.x        ProBook 4515s        RS780MN UMA        PCAC21        15.6        BLK
        Piaget 1.x        ProBook 4515s        RS780MN UMA        PCAC23        15.6        RED
        Piaget 1.x        ProBook 4515s        RX781 DSC WWAN        PCAC24        15.6        BLK
        Piaget 1.x        ProBook 4515s        RX781 DSC        PCAC26        15.6        RED
        Piaget 1.x        ProBook 4515s        RX781 DSC        PCAC27        15.6        BLK
        Piaget 1.x        ProBook 4515s        RS780MN UMA WWAN        PCAC29        15.6        RED
        Piaget 1.x        ProBook 4415s        RS780MN WWAN        PCAC30        14"        BLK
DT08-TT08        Turi 1.X        6535b                PC3521        14.1"
        Turi 1.X                        PC3526        14.1"
        Tanqueray 1.X        6735b                PC3501        15.4"
        Tanqueray 1.X                        PC3506        15.4"
DT08-DD08        Dubra 1.0        HP Compaq 6530b        IDS         PC4701        14.1"
        Dubra 1.0        HP Compaq 6530b        IDS WWAN        PC4706        14.1"
        Danzka 1.0        HP Compaq 6730b        IDS         PC4721        15.4"
        Danzka 1.0        HP Compaq 6730b        IDS WWAN        PC4726        15.4"
发表于 2011-7-28 17:37:18 | 只看该作者 �
你这个图纸表是什么意思?
我的是probook 6455b 这个图纸你有吗
发表于 2011-8-18 11:32:49 | 只看该作者 �
没看懂!!!
发表于 2011-9-5 14:13:38 | 只看该作者 �
LZ 对照表  怎么看 啊! 看不明白, 可否 指点 一二!
发表于 2011-9-6 09:14:18 | 只看该作者 �
这是新版对应表
发表于 2011-9-19 16:07:36 | 只看该作者 �
怎么没有人上传图纸啊?
发表于 2011-9-19 16:32:13 | 只看该作者 �
{:soso_e196:}这个我也看不懂,能否指教一二
发表于 2011-10-10 10:10:13 | 只看该作者 �
我想要compaq 321 的图纸和bios
发表于 2011-10-27 16:11:55 | 只看该作者 �
看不太懂啊。!
发表于 2011-11-1 13:21:31 | 只看该作者 �
我也没看懂啊,有HP PROBOOK4416S 的图纸吗?这台机子不引导是哪里的问题啊,求解
发表于 2011-11-3 15:54:44 | 只看该作者 �
汤雪松的你发的什么?
发表于 2011-11-24 15:50:12 | 只看该作者 �
发表于 2011-11-24 15:52:12 | 只看该作者 �
有的,你下Piaget 1.x
这个板号的图纸,就有了
哦,呵呵,现在已经用不上了,谢谢了,你知道为什么不引导吗  详情 回复 发表于 2011-11-25 19:49
发表于 2011-11-25 19:49:12 | 只看该作者 �
zhouguangbin9 发表于 2011-11-24 15:52
有的,你下Piaget 1.x
这个板号的图纸,就有了
发表于 2011-11-29 11:48:16 | 只看该作者 �
为什么不引导?你指的是系统吗,还是板
发表于 2011-12-23 10:56:33 | 只看该作者 �
有HP510点图吗?
