查看: 2257|回复: 5
[显卡维修]
ATI 9700显卡花屏求救
发表于 2010-3-29 01:01:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
这个是笔记本上的独立显卡,原本不过显卡,换了全新的GPU后变为大花屏,进系统能辨到鼠标位置,DOS下也能隐约看到光标。
拆下4片显存打板上的阻值OK, 打4片显存其中一片DQ线略低。换4片全新显存后还是一样。跑R3的结果如下:
R3MEMID version 1.07, (c) Copyright ATI Technologies Inc, 2003
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
TEST RESULT SUMMARY:
(0x4e50) detected.
64M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID 0VB001
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 0 1 2 3 4 5 6 7 ...
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID 0VB023
[3  ] RW page (GUI)                                       : FAIL
    Error ID 0VB025
[4  ] RW channel (GUI)                                    : FAIL
    Error ID 0VB028
[5  ] Data mask                                           : FAIL
    Error ID 0VB006
[6  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID 0VC006
    failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 0 1 3 4 5 6 7 8 ...
[7  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID 0VC018
[8  ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID 0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R051A.8 not found
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R052A.8 not found
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R053A.8 not found
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R055A.8 not found
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R061A.8 not found
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R062A.8 not found
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R063A.8 not found
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R065A.8 not found
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R071A.8 not found
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R072A.8 not found
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.8 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R075A.8 not found
[9  ] Line slopes/dir/P/solid                             : FAIL
    Error ID 0TR010
     error : R051A.9 not found
     error : R052A.9 not found
     error : R053A.9 not found
     error : R055A.9 not found
     error : R061A.9 not found
     error : R062A.9 not found
     error : R063A.9 not found
     error : R065A.9 not found
     error : R071A.9 not found
     error : R072A.9 not found
     error : R073A.9 not found
     error : R075A.9 not found
Failure detected.
再换一片GPU还是一样,实在没招。特在此求救!
最后发现是被人拿掉了个电感,标号L507,多谢各位的关注。
发表于 2010-3-29 23:51:21 | 只看该作者 �
有测过电压正常不?如果核心和显存都换了还是花,觉得应该和供电有关,或电容问题
发表于 2010-3-30 08:54:32 | 只看该作者 �
GPU没有换好
发表于 2010-3-30 09:52:34 | 只看该作者 �
后面的 全放出来看下
发表于 2010-3-31 22:08:05 | 只看该作者 �
2# 美丽的的谎言
修好了,确实是供电问题,L507被人故意拿掉了。没有点图,板上标号也不全,ATI9700也没有PDF参考,这个确实很难发现,最后对照好板才解决问题。
发表于 2010-3-31 23:07:01 | 只看该作者 �
呵呵。顶下。。
