查看: 2523|回复: 1
[求助中]
sf2281主控开卡提示错误ReadDriveConfigUnique怎么解决
发表于 2019-10-6 12:05:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
2281主控的固态硬盘,开卡过程到格式化完成就提示
[Fri 10/04/2019 13:04:30] - FORMAT command completed...
[Fri 10/04/2019 13:04:30] - Waiting (2 sec) for the drive to settle...
[Fri 10/04/2019 13:04:32] - Setting up the stamp information through CDU command...
[Fri 10/04/2019 13:04:32] - FATAL_ERROR: Could not perform the ReadDriveConfigUnique() operation on the drive... (0x00100001:SF_SATA_DEVICE_NOT_PRESENT_ERROR)
[Fri 10/04/2019 13:04:32] - End of Genesis manufacturing log.
[Fri 10/04/2019 13:04:32] - Exiting...
谁知道什么问题,麻烦哪位大神提示下,
转接卡 换过好多个 都这个问题
发表于 2019-10-6 16:10:57 | 只看该作者 �
就没人知道吗
