- 积分
- 1
- 下载分
- 分
- 威望
- 点
- 原创币
- 点
- 下载
- 次
- 上传
- 次
- 注册时间
- 2014-11-11
- 精华
发表于 2014-11-18 08:32:18
只看该作者
About PS/2 problem, you can follow my steps:
1. Check the Signals of PS / 2 link to I / O
2. Remove Capacitors on the Signal Line, after 330 and 472 RESIS That Replace
3. finally, change the I / O
About the USB does not Recognize in the Windows, you CAN Follow my Way
1. Check the correct voltage of USB Signals Data +, Data- and 5V power supply
2. change the Transistors on the Signal Line
3. finally, change SB.
I hope my Steps above CAN Help you resolve your problems. thanks you guys!
