查看: 3127|回复: 9
[显卡维修]
9600花屏,至今没有搞定
发表于 2011-6-22 18:49:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
最近生意不怎么样,把压箱的几块显卡拿来学习一下,,没想到第一块就没有搞定型号是ati9600 128M的,在DOS下全花,进XP,只有左边三分之一是花屏的,一般能显示,我就基本判断工作条件满足,直接用R3MEMID version 1.07版本测试,测试情况如下:TEST RESULT SUMMARY:
Rv350 (0x4152) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID 0VB001
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 0 1 2 3 4 5 6 7 ...
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID 0VB023
[3  ] RW page (GUI)                                       : FAIL
    Error ID 0VB025
[4  ] RW channel (GUI)                                    : FAIL
    Error ID 0VB028
[5  ] Data mask                                           : FAIL
    Error ID 0VB006
[6  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID 0VC006
[7  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID 0VC018
[8  ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID 0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R051A.8 not found
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R052A.8 not found
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R053A.8 not found
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R055A.8 not found
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R061A.8 not found
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R062A.8 not found
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R063A.8 not found
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R065A.8 not found
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R071A.8 not found
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R072A.8 not found
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.8 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R075A.8 not found
[9  ] Line slopes/dir/P/solid                             : FAIL
    Error ID 0TR010
     error : R051A.9 not found
     error : R052A.9 not found
     error : R053A.9 not found
     error : R055A.9 not found
     error : R061A.9 not found
     error : R062A.9 not found
     error : R063A.9 not found
     error : R065A.9 not found
     error : R071A.9 not found
     error : R072A.9 not found
     error : R073A.9 not found
     error : R075A.9 not found
Failure detected.
怎么看到A面和B面都有问题啊,无语了,改换别的方式 ,单独测了A线和D线的对地值,全都正常,直接加焊GPU,仍无好转,哪们朋友出来指点一下啊,谢谢。。。。。。我也是在论坛里面边学边修的,显卡维修正在学习中
发表于 2011-6-22 18:54:45 | 只看该作者 �
有时候这种卡内存控制器坏了,你看 9550的帖子,很多事这样的
发表于 2011-6-22 18:59:00 | 只看该作者 �
查查供电,有时也会造成花屏。这种卡要是长时间修不好,就扔了,没太多研究价值。除非是N卡的9600
发表于 2011-6-22 19:08:03 | 只看该作者 �
刚刚看一个贴子,好像说如果测到每个显存都有问题,一般是GPU坏了,是这样吗??
发表于 2011-6-22 23:22:52 | 只看该作者 �
先换AB通道第一颗显存
发表于 2011-6-25 14:11:51 | 只看该作者 �
楼主试过二楼的方法了吗
发表于 2011-6-25 23:49:30 | 只看该作者 �
一般供电正常的情况下,就只有GPU了
发表于 2011-7-15 12:38:40 | 只看该作者 �
最近比较忙,又放下了,有空再修!想问问大家,笔记本独立显卡板的BIOS如果坏了,有没有办法维修呢,没有相同的板?
发表于 2011-7-24 13:58:17 | 只看该作者 �
有些显存短路了 照成都报错 具体要打值才可以测得出来
发表于 2011-7-24 14:52:39 | 只看该作者 �
bios刷一下试试!
