查看: 1810|回复: 1
simmtronics mcp73pv bios require
发表于 2011-11-8 12:38:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
simmtronics mcp73pv bios require. its dual bios. one is user bios and other is safe bios. i want both the bios.
发表于 2011-11-8 15:33:18 | 只看该作者 �
You should not be here,Because we cannot read your problem, even to understand, cannot reply to you.
