查看: 8457|回复: 1
[内存维修]
关于内存的英文缩写解释
发表于 2007-4-15 07:14:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
ABP: Address Bit Permuting,地址位序列改变
ATC(Access Time from Clock,时钟存取时间)
BSRAM(Burst pipelined synchronous static RAM,突发式管道同步静态存储器)
CAS(Column Address Strobe,列地址控制器)
CCT(Clock Cycle Time,时钟周期)
DB: Deep Buffer(深度缓冲)
DDR SDRAM(Double Date Rate,双数据率SDRAM)
DIL(dual-in-line)
DIMM(Dual In-line Memory Modules,双重内嵌式内存模块)
DRAM(Dynamic Random Access Memory,动态随机存储器)
DRDRAM(Direct RAMbus DRAM,直接RAMbus内存)
ECC(Error Checking and Correction,错误检查修正)
EEPROM(Electrically Erasable Programmable ROM,电擦写可编程只读存储器)
FM: Flash Memory(快闪存储器)
FMD ROM (Fluorescent Material Read Only Memory,荧光质只读存储器)
PIROM:Processor Information ROM,处理器信息ROM
PLEDM: Phase-state Low Electron(hole)-number Drive Memory
QBM(Quad Band Memory,四倍边带内存)
RAC(Rambus Asic Cell,Rambus集成电路单元)
RAS(Row Address Strobe,行地址控制器)
RDRAM(Rambus Direct RAM,直接型RambusRAM)
RIMM(RAMBUS In-line Memory Modules,RAMBUS内嵌式内存模块)
SDR SDRAM(Single Date Rate,单数据率SDRAM)
SGRAM(synchronous graphics RAM,同步图形随机储存器)
SO-DIMM(Small Outline Dual In-line Memory Modules,小型双重内嵌式内存模块)
SPD(Serial Presence Detect,串行存在检查)
SRAM(Static Random Access Memory,静态随机存储器)
SSTL-2(Stub Series Terminated Logic-2)
TSOPs(thin small outline packages,超小型封装)
USWV(Uncacheable, Speculative, Write-Combining非缓冲随机混合写入)
VCMA(Virtual Channel Memory architecture,虚拟通道内存结构)
[ 本帖最后由 张先生 于 2007-4-15 07:17 编辑 ]
参与人数 1下载分 +10 收起 理由
贝贝 + 10 好资料
发表于 2007-4-15 09:14:11 | 只看该作者 �
抢沙发 !
