查看: 4417|回复: 13
[内存维修]
有谁用过RAMCHECK LX DDR3/DDR2 这玩意吗
发表于 2010-10-26 19:28:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
各位修内存的老大,这种测试R3/R2的仪器 谁用过没 效果如何啊
好东西。。。这个才是  发表于 2010-10-27 10:58
发表于 2010-10-26 20:34:40 | 只看该作者 �
The RAMCHECK memory tester offers you an affordable way to quickly and reliably test and identify all popular laptop and desktop computer memory, including DDR3, DDR2 and PC466/433/400 DDR and 168-pin SDRAM. With its optional adapters, you can also test 144-pin and 200-pin laptop SODIMMs, DDR chips, Sun Microsystems memory, even old SIMMs, EDO and FPM modules.  RAMCHECK is expandable, allowing you to test:  DDR3, DDR2, DDR1
168-pin SDRAM
SO-DIMMs*
SIMMs*
Chips*
*With optional adapters.
To test a module and do a speed verification, simply turn the on the RAMCHECK memory tester, insert the memory module into the test socket, then press the Start button. Since there are no complex setups to master, the RAMCHECK memory tester can be used "out of the box." Of course, you can also customize the test parameters if you have more advanced testing needs.
TheRAMCHECK tester relies on a powerful high-frequency test engine. With its proven test algorithms and modular, expandable design, RAMCHECK delivers superior memory testing at an affordable price.
The RAMCHECK memory tester is also simple to upgrade, with free firmware upgrades available via the Internet. A PC software program is also included, allowing you to print/log the test results and edit SPD data.
RAMCHECK LX, our latest memory tester, is now available. RAMCHECK LX features a bright, vivid display easily visible from any angle, plus a fast USB connection.
The RAMCHECK LX DDR3 can test and identify a 1GB DDR3 DIMM in less than 30 seconds. RAMCHECK LX is simple to use. It features a bright, vivid display easily visible from any angle, plus a fast USB connection.
RAMCHECK LX works with all current RAMCHECK adapters and is available in different packages that best fit your testing needs.
老兄 抄这个过来做什么啊 我要看的是这仪器的效果哦  发表于 2010-10-26 21:17
发表于 2010-10-27 08:52:59 | 只看该作者 �
弄个国语。
那方言有点看不懂
发表于 2010-10-27 12:11:24 | 只看该作者 �
效果 不用怀疑,至少搞掉9。5成以上破内存。
发表于 2010-10-27 13:16:51 | 只看该作者 �
有个外国老再卖要1000多美圆。
在哪里卖 是能测二三代的么 1000多美金 我买一个  发表于 2010-10-27 22:47
发表于 2010-10-27 13:34:42 | 只看该作者 �
这个机器安逸哟
发表于 2010-10-27 15:36:39 | 只看该作者 �
1000多美元,那要7000块左右啊~~~~我们自己国家不能生产一个这样的吗!那样成本会低很多的~~~~
发表于 2010-10-27 23:01:03 | 只看该作者 �
我用过修一代的还可以.DDR2不太理想.1000美金买不到的、
发表于 2010-10-28 13:34:17 | 只看该作者 �
这个还没有安信历害呢
呵呵,我的技术不止7000,我只要修理好2G的30-40条7000就到手,只要货源充足一天就到手。还有单片机搞出来的内存不太放心,兼容性和稳定性我总是不太放心。人才是技术的关键,  发表于 2010-10-28 13:53
发表于 2010-10-28 14:07:31 | 只看该作者 �
看来你的内存是翻新卖的,佩服,通常这样的内存卖得不好,技术这个东西是无价的,在一个人的脑子里,如果能买到的话,那就太好了,如果钱能解决的,那就都不是事,我认为人品是技术的关键,技术再好,人品差,这个人也好不到哪去,所以待人接物还是要低调谦逊的好,
发表于 2010-10-28 14:42:43 | 只看该作者 �
回复 安信电器商行 的帖子
外国老的论坛,他要1000多美圆。
发表于 2010-10-28 15:11:27 | 只看该作者 �
我先回答你的问题:
意思我人品很差?哈哈,问问论坛到我这里学习技术的兄弟和我相处的朋友,我最看不起的就是只喜欢免费获取,不涉及技术金华的可以说说,高级技术想白搞到手?做梦。
,想学习东西,其他要有点诚意,谁欠你的技术,愿意说的人就说,不愿意说就不说,说话谦和点我还说几句,这个是个人的自由。又不是我的徒弟我根本没有必要承担教授技术的责任,
内存不好卖?我的渠道很多,在主板,内存,显卡我的销路很大,有我师傅和朋友的帮忙和提拔,基本供不应求。谢谢你多操心了。多谢你的好意/
谁都喜欢免费,在基地论坛可以学习到很多入门的东西,但是想提高自己只有去杭州实战学习,比如基地卖的显卡维修的书,现在都卖得很火。
既然什么都免费,大家还要去学习和买资料。你动动你脑筋。。
还有这里是论坛。不要一天到晚对我指手划脚,你有本事露几手实战看看。或者发个很权威的软件来看看。
我劝你不要动不动谈什么人品,先把自己整理好了再谈论我的人品。谢谢
发表于 2010-10-29 09:47:49 | 只看该作者 �
哈哈哈,你倒挺有意思 ,我倒没说你的人品差,是你多想了,通过以这句话:有我师傅和朋友的帮忙和提拔,基本供不应求    说明你眼里还是有人的,
夸自己不要把论坛摆到最高处,整的像党员作报告似的,技术很高的人也不都是在论坛学成的吧,东西卖得活不活和他性价比有直接的关系,物美价廉当然人人都喜欢,但不代表就一定要免费,毕竟有很多专业的东西是科研人员的成果,这个也免费了对人家是不公平的,但是某些人拿出来送了,卖了,就是你自己的问题,因为是你先不遵守行规的
我嘛,技术很一般,就是一个你们说的小小白,人品嘛,说得过去,但是我不叽歪,呵呵
还是你牛批,劳资闪人一法式,天天有钞票捞不快,等我杀完这捆显卡再来吼。。。  发表于 2010-10-29 10:43
发表于 2010-10-29 12:00:22 | 只看该作者 �
虽说是搞技术的大多都是粗人,但相比真正的粗人,咱们还是有文化的人,而且论坛的气氛是很好的,所以尽量要文明用语,相对比来讲,你是大师级别的,因为我只是一个业余爱好者,喜欢琢磨,所以你是师傅,就不要和我吼了
