查看: 2943|回复: 11
[维修经验]
ga-8l533 no power (solved)
发表于 2010-3-13 21:37:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
Visual values are no problem playing, plug in the power test card was found on the 3.3VSB standby light does not shine
PC114 pin voltage is measured only 0.02V should be 3.3V】 【normal
No standby voltage, first of all on-board to find standby voltage generator components, found a 1117 and a 1084
In order to determine that is to generate 3.3VSB voltage components, a table pen then A14, a table pen test to 11173 feet. 11173 feet and the A14 was found attached to illustrate the feet 3.3VSB VCC switch to 1.5V SB VCC voltage components.
Test-retest 10842 feet and 11173 feet, similarities demonstrate that it is 5V SB over 1084 conversions 3.3V SB, then certainly 3.3V SB come from the 1084 conversion.
Under normal circumstances, the direct access 5VSB pin sub-10843 replaced 3.3V SB, measuring purple 5V SB with 10843 feet was found not directly linked to
5V SB line was found running with the CPU near Block LM393 comparator 8-pin connected
[local]22[/local]
Cha LM393 data, 8-pin power supply pin, a pin for the way out, way out to 7 feet
[local]29[/local]
Kick start running line, was found into a 6-foot sesame tube 3 feet, model D1Y13
[local]23[/local]
View Sesame tubes found in 1256 pin-pin connected together, then 10843 feet. 4 feet direct access 5VSB
I do not know what it is 6 feet, help the master craftsman was the sesame tube pin map, found a P pipe ditch
Pin diagram found on the tube voltage electric measuring 4 feet sesame seeds (S) 5V
[local]20[/local]
[local]28[/local]
Test-retest 3-pin (G) voltage is 5V, P-channel MOS control voltage until the output should be 0V. No wonder there is no standby voltage of 10843 feet, the original output of this tube did not
[local]32[/local]
Prior to running lines of this MOS tube is then 393 of the G pole. So check the working conditions of 393. Measuring 393 positive input pin, the voltage of 0V
Test-retest reverse input voltage 2.5V
Test-retest output pin 5V, this is obviously and 393 works contrary. Under normal circumstances only the positive input is higher than when the reverse input, the output pin until the output voltage, suspected damage 393.
[local]30[/local]
Replacement of 393 and then measuring the forward voltage input pin, the voltage of 0V
Reverse input voltage remains at 2.5V
Test-retest output pin, and now a voltage of 0V
MOS control voltage for 0V the
MOS pipe D has a normal output of 5V has an extremely
[local]24[/local]
10843 feet finally 5V Voltage
Point switch trigger, smooth boot
U test voltage is normal on the boot memory to run code on the display. Repair faults.
[local]21[/local]
发表于 2010-3-14 09:30:30 | 只看该作者 �
高学历修机就是不一样。。 图看了, 但英文就看不太懂了,跟维修相关的专业术语可以。。 也没功夫搞翻译。
作为基地的兄弟,你应该体谅下,搞维修的,很多兄弟学历都不是很高。
发表于 2010-3-14 10:24:04 | 只看该作者 �
我看不是中国的。。上传图片很专业啊。。新加坡的?、、
发表于 2010-3-14 10:41:51 | 只看该作者 �
哈哈,看不懂英文。水平有限啊
发表于 2010-3-14 11:07:39 | 只看该作者 �
搞维修的大都两把刷子,判断和更换.这位仁兄是搞电路设计的吧.
发表于 2010-3-14 11:28:20 | 只看该作者 �
兄弟, 就不要考练 大家了英语老,,,, 看得脑壳大
发表于 2010-3-14 11:52:17 | 只看该作者 �
高手就是不一样,这么几个图就搞定了。学习了
发表于 2010-3-14 12:26:01 | 只看该作者 �
看的累啊,还在网上一个一个的查翻译过去。 哈哈,  不过这图己经够明确了
发表于 2010-3-14 12:30:12 | 只看该作者 �
LZ,你可以去吃S了,在这里卖弄学问,纯SB一个。还全英文的.........
发表于 2010-3-15 07:18:21 | 只看该作者 �
就知道诊断卡是一样的
发表于 2010-3-15 10:37:51 | 只看该作者 �
1# 法赫米
      是在哪里转载的吧, 不过值得学习
发表于 2010-3-15 10:51:42 | 只看该作者 �
冒看懂,貌似很高手
