查看: 4689|回复: 3
IR3567B
发表于 2022-12-9 22:39:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
修了个华硕猛禽RX5700,显存供电管理芯片,
这个芯片带程序,我从我手里料板找到了几个从R9380 r9furyX 等显卡上找到相同芯片测试后基本相同,关于芯片上油漆颜色区分不同程序的说法目前我还没测出来,有知道的小伙伴么?
发表于 2022-12-10 09:02:00 | 只看该作者 �
颜色一样,相数一样
发表于 2022-12-10 11:51:38 | 只看该作者 �
供电芯片带程序,809 能刷吗?显卡以后越来越难搞了。
发表于 2022-12-10 12:00:04 | 只看该作者 �
IR’s unique Adaptive Transient Algorithm (ATA), based
on proprietary non-linear digital PWM algorithms,
minimizes output bulk capacitors and Multiple Time
Programmable (MTP) storage saves pins and enables
a small package size. Device configuration and fault
parameters are easily defined using the IR Digital
Power Design Center (DPDC) GUI and stored in onchip MTP
The IR3567B provides extensive OVP, UVP, OCP and
OTP fault protection and includes thermistor based
temperature sensing with VRHOT signal.
