查看: 1207|回复: 0
联想M8500t-N0000BIOS Update (Operating System Version)
发表于 2024-3-3 12:27:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
联想M8500t-N0000 ThinkCentre BIOS更新程序,在操作系统中更新。
操作方法:
Extracting the package======================1. Click Start, select Find or Search, then click All files and folders.2. Type fbjye0usa.exe in the search field, then click Find Now or    Search Everywhere. This will locate the file you just downloaded.3. Double-click the fbjye0usa.exe icon.4. Read the license agreement5. Click I accept the terms in the license agreement.6. Click Next.7. Ensure that "Save files in folder" is set to   C:\SWTOOLS\FLASH\FBJYE0USA8. Click Next.9. Click Finish.Installing the package======================  Please print out these instructions or write them down beforestarting this flash update utility.        This flash under operating system (32-bit/64-bit) utility providesthe ability to update the system flash from a windows application.                                                             The utility may be downloaded from the internet and unpacked into the default path: "C:\SWTOOLS\FLASH\FBJYxxUSA", where "xx"   represents the two digit flash level. After unpacking the utility,please follow steps in section 2 to launch the windows based flashapplication to update your system.        1.  Please make note of any settings you have changed in the BIOS     Setup utility. They may have to be re-entered after updating      the BIOS.        2.  Open folder "C:\Windows\System32", locate the file "cmd.exe".     Right-click on this application, select "Run as administrator"    to open the "Command Prompt" with Administrator privilege.        3.  Input command "cd C:\SWTOOLS\FLASH\FBJYxxUSA\", where "xx"        represents the two digit flash level.        4.  Then input command "flash.cmd" to start flash process.        5.  You will see the prompt "Would you like to update the Serial      Number?". Input "n" and press Enter.        6.  Then you will see the prompt "Would you like to update the        Machine Type and Model?". Input "n" and press Enter again.        Then the BIOS update process will start.        7.  Update may take up to 2 minutes. Do not power off or restart      the system during this procedure! After Windows update process    ends, the system will automatically reboot to continue the flash    process.        8.  After system reboot, the BIOS update process will continue with     a graphic UI. When the BIOS update process ends, the system       will reboot automatically.        9.  You may see a POST error "0162: Setup data integrity check        failure" after reboot. It is a normal behavior. Press F1 to       enter BIOS Setup Utility. If you are using WIN8 64-bit OS,        change the Exit->OS Optimized Defaults to "Enabled", otherwise,     please change it to "Disabled". At last, press F10 to save        your settings.        10. The BIOS update process ends with the above nine steps.
fbjye0usa.exe
5.78 MB, 下载次数: 8, 下载积分: 下载分 -2 分
