查看: 2167|回复: 0
LM032L液晶 8051 LCD Driver仿真及程序
发表于 2016-3-21 18:16:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
ISIS 7 Professional
自带的电路仿真图,压缩包里面有hex文件,可以直接打开使用
  • ; LCD Display Driver Demo.
  • ; Timing code assumes 1.2MHz Clock
  • ;LCD Registers addresses
  • LCD_CMD_WR        equ         0
  • LCD_DATA_WR        equ        1
  • LCD_BUSY_RD        equ        2
  • LCD_DATA_RD        equ        3
  • ;LCD Commands
  • LCD_CLS                equ        1
  • LCD_HOME        equ        2
  • LCD_SETMODE        equ        4
  • LCD_SETVISIBLE        equ        8
  • LCD_SHIFT        equ        16
  • LCD_SETFUNCTION        equ        32
  • LCD_SETCGADDR        equ        64
  • LCD_SETDDADDR        equ        128
  • ;Reset vector
  •         org 0000h
  •         jmp start
  • ;Start of the program
  •         org 0100h
  • string1a:db ' !! A M A Z I N G !! '
  •          db 0
  • string1b:db '!! A M A Z I N G !! '
  •          db 0
  • string2:db ' A virtual LM032L... '
  •         db 0
  • string3:db ' driven by a virtual '
  •         db 0
  • string4:db '   8051 processor!'
  •         db 0
  • start:        mov A,#038h
  •         call wrcmd
  • loop:        mov A,#LCD_SETVISIBLE+6         ;Make the display & blink visible:
  •         call wrcmd
  •         mov R7,#2
  • loop2:
  •         mov DPTR,#string1a
  •         call wrstr
  •          mov DPTR,#200
  •          call wtms
  •         mov A,#LCD_CLS                        ;Clear screen
  •         call wrcmd
  •         mov DPTR,#string1b
  •         call wrstr
  •          mov DPTR,#200
  •          call wtms
  •         call wrcmd
  •         djnz R7,loop2
  •         call wrstr
  •          mov DPTR,#400
  •          call wtms
  •         mov A,#LCD_SETDDADDR+64
  •         call wrcmd
  •         mov DPTR,#string2
  •         call wrslow
  •          mov DPTR,#200
  •          call wtms
  •         call wrcmd
  •         mov DPTR,#string3
  •         call wrslow
  •         call wrcmd
  •         mov DPTR,#string4
  •         call wrslow
  •         mov A,#LCD_SETVISIBLE+7                ;Show the blink cursor as well.
  •         call wrcmd
  •          mov DPTR,#2000
  •          call wtms
  •         call wrcmd
  •         jmp loop
  • ;Sub routine to write null terminated string at DPTR in program ram.
  • wrstr:        mov R0,#LCD_DATA_WR
  • wrstr1:        clr A
  •         movc A,@A+DPTR
  •         jz wrstr2
  •         movx @R0,A
  •         call wtbusy
  •         inc DPTR
  •         push DPL
  •         push DPH
  •         pop DPH
  •         pop DPL
  •         jmp wrstr1
  • wrstr2:        ret
  • ;Sub routine to write null terminated string at DPTR in program ram. Slowly
  • wrslow:        mov R0,#LCD_DATA_WR
  • wrslw1:        clr A
  •         movc A,@A+DPTR
  •         jz wrslw2
  •         movx @R0,A
  •         call wtbusy
  •         inc DPTR
  •         push DPL
  •         push DPH
  •         mov DPTR,#100
  •         call wtms
  •         pop DPH
  •         pop DPL
  •         jmp wrslw1
  • wrslw2:        ret
  • ;Sub routine to write command:
  • wrcmd:        mov R0,#LCD_CMD_WR
  •         movx @R0,A
  •         jmp wtbusy
  • ;Sub routine to write character:
  • wrchar:        mov R0,#LCD_DATA_WR
  •         movx @R0,A
  • ;Subroutine to wait for busy clear
  • wtbusy: mov R1,#LCD_BUSY_RD
  •         movx A,@r1
  •         jb ACC.7,wtbusy
  •         ret
  • ;Wait for number of seconds in A
  • wtsec:        push ACC
  •         call wtms
  •         pop ACC
  •         dec A
  •         jnz wtsec
  •         ret
  • ;Wait for number of milliseconds in DPTR
  • wtms:   xrl DPL,#0FFh                        ;Can't do DEC DPTR, so do the loop by forming 2's complement
  •         xrl DPH,#0FFh                        ;and incrementing instead.
  •         inc DPTR
  • wtms1:        mov TL0,#09Ch                        ;100 ticks before overflow = 1ms at 1.2MHz Clock
  •         mov TH0,#0FFh
  •         mov TMOD,#1                        ;Timer 0 mode 1
  •         setb TCON.4                        ;Timer 0 runs
  • wtms2:        jnb TCON.5,wtms2
  •         clr TCON.4                        ;Timer 0 stops
  •         clr TCON.5
  •         inc DPTR
  •         mov A,DPL
  •         orl A,DPH
  •         jnz wtms1
  •         ret
  •         END
