查看: 2411|回复: 6
CQ40 (LA-4101P) LAPTOP CHARGING PROBLEM
发表于 2011-11-8 12:34:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
i receive a CQ40 (LA-4101P) laptop with charging problem. its charging led is glow without battery also and the charging voltage also come in battery connector. when i power on the laptop its working fine for 1-2 min after that the charging led is blinking and power off automatically. i replace the bq24740(PU101) ic but not solved. without PU101 also the charging led is on and aftersometime blinking & power off.
发表于 2011-11-8 13:13:11 | 只看该作者 �
晕。这那看得懂啊。来中文的吧。
发表于 2011-11-8 14:07:20 | 只看该作者 �
中文  中文
发表于 2011-11-8 15:27:41 | 只看该作者 �
I understand your question,it Is a charging circuit problem.Battery and the charging voltage is not compatible.You'd better replace charging chip,PU101 is it right? You said charging chip.
发表于 2011-11-8 15:42:49 | 只看该作者 �
This machine for BIOS problem.
发表于 2011-11-8 19:39:38 | 只看该作者 �
发表于 2011-11-8 21:11:01 | 只看该作者 �
WHERE ARE YOU FORM?
