查看: 1793|回复: 3
please explain the funtionfor I/O or EC chip work
发表于 2010-1-24 17:01:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
my newbie for repair notebook . I don't understand for level process for I/O or then call EC chip . Everyone please explain the funtion of I/O or  so called  "EC Chip" EX.97551,WD910  by use schematic diagram  and tell me hoe to check if the IC work or not
发表于 2010-1-24 17:17:49 | 只看该作者 �
你的意思是问开机芯片,键盘管理芯片 I/O等的功能和工作时序和条件吗?
发表于 2010-1-24 17:34:18 | 只看该作者 �
YES!!!!!
发表于 2010-1-25 09:53:01 | 只看该作者 �
Everybody no answer to me!!!
