查看: 3427|回复: 1
[系统故障]
断网急救箱总提示HOSTS配置异常
发表于 2020-2-3 19:29:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
win7 64位系统,近来发现网页打开有些不正常,用360断网急救箱检测发现HOSTS配置异常,修复后再检测又是HOSTS配置异常,手动找到windows\system32\drivers\etc下面的hosts文件用记事本打开清除掉除以下内容外的任何内容再保存替换,发现也不行。后来发现是银联插件的原因,一直自动添加好像是防止windows 7升级到win10的代码,在控制面板的程序和功能中找到银联的插件,卸载掉,再用360断网急救箱检测修复后再检测,发现就正常了。
附hosts文件中的原始内容:
# Copyright (c) 1993-1999 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
#      102.54.94.97     rhino.acme.com          # source server
#       38.25.63.10     x.acme.com              # x client host
#127.0.0.1       localhost
发表于 2020-2-14 14:33:32 | 只看该作者 �
host还是不如直接路由表好用
