查看: 1949|回复: 7
Pc410 new use
发表于 2016-12-6 17:36:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
Hi there
Recently i bought a new temperature controller for my cf360 machine from aliexprss, first use with programming parameters like as old one, controller heat quickly and reach high temperature in less than 2 minutes!! Where's the problem?
发表于 2016-12-6 19:39:08 | 只看该作者 �
楼主哪国人?..........
发表于 2016-12-6 21:48:56 | 只看该作者 �
虽说加热过快,但实际温度准不准呀
发表于 2016-12-8 00:30:56 来自迅维网APP | 只看该作者 �
I think the pc410 has firmware bug,is there a way to brush firmware?
发表于 2016-12-8 03:02:09 来自迅维网APP | 只看该作者 �
Controller temperature not respect programmed curves
发表于 2016-12-15 20:17:53 | 只看该作者 �
是哪国的呀
i'm from morocco  详情 回复 发表于 2016-12-15 23:21
发表于 2016-12-15 23:21:05 | 只看该作者 �
i'm from morocco
发表于 2016-12-16 00:07:43 | 只看该作者 �
摩洛哥  兄弟呀  你好呀
