标题: Fujitsu LH532 [打印本页] 作者: balu457157 时间: 2016-6-18 19:01 标题: Fujitsu LH532 Friends.. i have an issue in Fujitsu LH532 Model Laptop.
Issue: No power - first i faced no power 3.3V not coming i just checked with IO ic some Drops water been spread on that Chip. i Cleaned and put the power.. 3.3V came.. but display not came.
Bios- after i replace the bios program via Chiafix.com display came..
But my issue is after 1hr that bios getting error. laptop gone to Not on mode..
1mb bios getting void..
i just replaced IO and CMOS battery also but still it came same problem..
