我的'2.5吋筆盤,測試顯示最大的安全性锁定的問題
fjsli
2016-6-17 17:05
我的2.5吋盤,我用VICTORIA4.2顯示以下訊息
請問要這樣修
Model: FUJITSU MJA2400BH G1
Firmware: 00000018
Serial: K92JT95257DA
Disk size: 781422768 LBAs 381554 Mb
CHS: 16383/16/63 8063 Mb
SMART: Enabled, Errlog, Selftest
CACHE: 8192k; L/A=ON; Wr=ON; ok
Support: LBA, HPA, AAM, APM, DLM, DMAUDMA-5
AAM val: 254 Maximum
APM val: 128 Minimum
Erase: ~400 minutes
Status: Passed
Spindle: Active --------------------------------------------------------------
Security: ON, Max, Locked *Expired
ATA-8: SCT, SFDLM, WrUnk
