标题: ACE PC3000做硬盘 同时指令无响应,数据恢复方法 [打印本页]
作者: 军达成    时间: 2016-3-23 09:46
LED:00000047 希捷F3 MCMT报错不识别恢复数据-1
同时指令无响应
ST1000DM003  FW:CC4G
终端报错如下。
Boot 0x40M
Spin Up
TCC-001D[0x00026F7C][0x000273E8][0x00027854]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
TCC-001D
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MCMainPOR: EXCEPTION: MCMT PRI copy corrupt
MCMainPOR:  MCMT SEC copy valid
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 0A61
Nonvolatile MCMT sequence number 00545CBF
[RSRS] 05E4
ProcessRWError -Read-   at LBA 000000000004C393  Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 000000000004C393!
Reconstruction: EXCEPTION: Seg Read Fail: Status = 0000
Continuing after error
Reconstruction: Completed 1:
[MCMTWS]
Rst 0x40M
Spin Up
TCC-001D
LED:00000047 FAddr:FFFFFFFE
解决方法:
Rst 0x40M
Spin Up
TCC-0024                                    (看这里,读固件自检完成再短路)板号:100664987-REV B
(DOS) Table Read FAIL
DOS: MAGIC CONFIG NUMBER MISMATCH
(DOS) Requesting File Save
MCMainPOR: EXCEPTION: SIM aborted prior to MCMT read
MCMainPOR: EXCEPTION: POR Failed General
MCMainPOR: Feature Disabled...
Starting LBA of RW Request=0000000000087B14  Length=00000174
ProcessRWError -Read-   at LBA 0000000000087B14  Sense Code=43110081
Total AC8, Head AA0, Tail 28 Retry 0 Status 0
Total AC8, Head AA0, Tail 28 Retry 1 Status 0
Total AC8, Head AA0, Tail 28 Retry 2 Status 0
Starting LBA of RW Request=0000000000087B18  Length=00000170
ProcessRWError -Read-   at LBA 0000000000087B18  Sense Code=43110081
Starting LBA of RW Request=0000000000087B1C  Length=0000016C
ProcessRWError -Read-   at LBA 0000000000087B1C  Sense Code=43110081
Starting LBA of RW Request=0000000000087B20  Length=00000168
ProcessRWError -Read-   at LBA 0000000000087B20  Sense Code=43110081
Starting LBA of RW Request=0000000000087B24  Length=00000164
ProcessRWError -Read-   at LBA 0000000000087B24  Sense Code=43110081
Starting LBA of RW Request=0000000000087B28  Length=00000160
ProcessRWError -Read-   at LBA 0000000000087B28  Sense Code=43110081
Starting LBA of RW Request=0000000000087B2C  Length=0000015C
ProcessRWError -Read-   at LBA 0000000000087B2C  Sense Code=43110081
Starting LBA of RW Request=0000000000A9C053  Length=00000001
ProcessRWError -Read-   at LBA 0000000000A9C053  Sense Code=C4090082
Starting LBA of RW Request=0000000000A9C054  Length=00000001
ProcessRWError -Read-   at LBA 0000000000A9C054  Sense Code=C4090082
Total AC8, Head AA0, Tail 28 Retry 2 Status 0[0000000000A9C053]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
ProcessRWError -Write-  at LBA 0000000000A9C053  Sense Code=C4090081[0000000000A9C054]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
ProcessRWError -Write-  at LBA 0000000000A9C054  Sense Code=C4090081[0000000000087B14]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
ProcessRWError -Write-  at LBA 0000000000087B14  Sense Code=C4090081[000000000E993B4C]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q[000000000E993B4D]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q[000000000E993B4E]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
FAILED to spare00000903
Device Fault is set!
No HOST FIS-ReadyStatusFlags 0002A1A5
ASCII Diag mode
F3 T>
ASCII Diag mode
出现指令后。写   系统文件: 03     346    .COPY1 写到COPY0.
断电上电后,指令有反应,不再锁定。
F3 T>
Boot 0x40M
Spin Up
TCC-0023[0x00026F7C][0x000273E8][0x00027854]
Trans.
Rst 0x40M
Spin Up
TCC-0023
SIM Error 2040 LBA 000000000008E913 FD FC351028
RW Error 00000080
MCMainPOR: Feature Disabled... PASS
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>/
F3 T>m0,6,2,,,,,22                (执行重建编译器)
Max Wr Retries = 00, Max Rd Retries = 00,  Max Iterations = 01, Max Certify Rewrite Retries = 000C
User Partition Format Successful - Elapsed Time 0 mins 00 secs
Zone re-format was skipped.
F3 T>
断电上电。硬盘可以识别并读取数据。
Boot 0x40M
Spin Up
Trans.
Rst 0x40M
Spin Up
TCC-0023
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Factory Init
MCInitialize: Start:  Buffer Words VBM: 00000210
ClearMC: Start Full  Media Cache size in host blks 00432380.....
ClearMC:  Completed, Last LBA 00432380
MCInitialize:  MC Cleared
MCInitialize:  MCTBufferPtr->Header.MCTStateFlags = 0000000A
MCInitialize:  MCTBufferPtr->Header.MCStateFlagsDisc = 00000001
MCInitialize:  MCStateFlags = 00000001
Set MCMT Version Current
[MCMTWS]
MCInitialize: Init complete:
MCMainPOR: MCTStateFlags 00000022  MCStateFlags 00000041
MCMainPOR: Feature Enabled...
(DOS)STE OGHT: 0x00000000000E8BD6 - 0x00000000000EB55E - 0x000004F0 - 0x0000050E Count 0047
(DOS)CMP Count 0047
(DOS)STE OGHT: 0x0000000000AAD22F - 0x0000000000AB06BC - 0x00003594 - 0x000035B2 Count 0049
(DOS)CMP Count 0049
(DOS)STE OGHT: 0x0000000000AAD07D - 0x0000000000AB050A - 0x00003593 - 0x000035B1 Count 004F
(DOS)CMP Count 004F
(DOS)STE OGHT: 0x00000000000E8E84 - 0x00000000000EB80C - 0x000004F2 - 0x00000510 Count 0048
(DOS)CMP Count 0048
(DOS)STE OGHT: 0x00000000000E8FDB - 0x00000000000EB963 - 0x000004F3 - 0x00000511 Count 0047
(DOS)CMP Count 0047
(DOS)STE OGHT: 0x00000000000D7130 - 0x00000000000D9E98 - 0x0000050A - 0x00000528 Count 0047
(DOS)CMP Count 0047
(DOS)STE OGHT: 0x0000000000AA566D - 0x0000000000AA8AFA - 0x0000354B - 0x00003569 Count 0040
(DOS)CMP Count 0040
PowerState = IDLE1
硬盘可以识别并提取数据。
作者: sxszjzx    时间: 2016-3-23 10:18
一直想学PC3000就是看不懂
作者: luxiangli1988    时间: 2016-3-23 11:48
正版 的太贵了,想买套来整整
作者: 军达成    时间: 2016-3-23 14:44
有什么需求的可以联系我,QQ号3049573632
作者: xuxiaozhong    时间: 2016-3-23 15:13
看不懂
作者: 小呀小学生    时间: 2016-3-23 17:14
不太擅长搞这个,学习了
作者: 蜡笔小白    时间: 2016-3-23 22:09
哎,怪咱们太爱国,看不懂外语
作者: cobgtkgtk    时间: 2016-3-24 09:28
这是啥原理呢
作者: zhupeng888    时间: 2016-3-25 12:51
这是啥原理看不
作者: gerh    时间: 2016-3-26 11:34
有点没看懂。。。。。
作者: cqscs0918    时间: 2016-3-26 17:13
楼主壳有哦
作者: ZH飞雪    时间: 2016-3-26 17:37
这个帖子好
作者: 军达成    时间: 2016-3-28 10:24
中华飞雪 发表于 2016-3-26 17:37
这个帖子好
哈哈,你在论坛里边能看到的,谢谢捧场啊
作者: 唐/footb宇    时间: 2016-3-28 15:30
短接啊
作者: 惠科    时间: 2016-4-2 10:58
军达成V5。。。。。。。
