标题: 您可以查看索尼液晶电视电源这样。 [打印本页] 作者: anmol 时间: 2016-3-10 23:04 标题: 您可以查看索尼液晶电视电源这样。 You can view this Sony LCD TV power.
1: Disconnect the LED board or motherboard and plug the inverter.
2: a jump from one foot to do STBY3.3 V to pin 3 POWER_ON (1K resistor is the best,
3: Connect the 12-volt watt or 10-watt light bulb glow lamp 35 AUTO then, and may be fined.
If the light flashes, then you need to replace the main part of the capacitance
And replace all MOSFET
