* 晶振:11.0592MHZ ******************************************************************/ #include <reg52.h> #define uchar unsigned char #define uint unsigned int sbit DS=P2^2; //define interface uint temp; // variable of temperature uchar flag1; // sign of the result positive or negative sbit wela1=P2^4; //段选信号的锁存器控制 sbit wela2=P2^5; sbit wela3=P2^6; //段选信号的锁存器控制 sbit wela4=P2^7; //位选信号的锁存器控制 sbit beep=P2^3; unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d, 0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71}; unsigned char code table1[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd, 0x87,0xff,0xef}; void delay(uint count) //delay { uint i; while(count) { i=200; while(i>0) i--; count--; } } void dsreset(void) //send reset and initialization command { uint i; DS=0; i=103; while(i>0)i--; DS=1; i=4; while(i>0)i--; } bit tmpreadbit(void) //read a bit { uint i; bit dat; DS=0;i++; //i++ for delay DS=1;i++;i++; dat=DS; i=8;while(i>0)i--; return (dat); } uchar tmpread(void) //read a byte date { uchar i,j,dat; dat=0; for(i=1;i<=8;i++) { j=tmpreadbit(); dat=(j<<7)|(dat>>1); } return(dat); } void tmpwritebyte(uchar dat) //write a byte to ds18b20 { uint i; uchar j; bit testb; for(j=1;j<=8;j++) { testb=dat&0x01; dat=dat>>1; if(testb) //write 1 { DS=0; i++;i++; DS=1; i=8;while(i>0)i--; } else { DS=0; //write 0 i=8;while(i>0)i--; DS=1; i++;i++; } } } void tmpchange(void) //DS18B20 begin change { dsreset(); delay(1); tmpwritebyte(0xcc); // address all drivers on bus tmpwritebyte(0x44); // initiates a single temperature conversion } uint tmp() //get the temperature { float tt; uchar a,b; dsreset(); delay(1); tmpwritebyte(0xcc); tmpwritebyte(0xbe); a=tmpread(); b=tmpread(); temp=b; temp<<=8; //two byte compose a int variable temp=temp|a; tt=temp*0.0625; temp=tt*10+0.5; return temp; } void display(uint temp) //显示程序 { uchar A1,A2,A2t,A3; A1=temp/100; A2t=temp%100; A2=A2t/10; A3=A2t%10; wela4=0; P0=table[A1]; //显示百位 wela1=1; delay(2); wela1=0; delay(1); P0=table1[A2]; //显示十位 wela2=1; delay(2); wela2=0; delay(1); P0=table[A3]; //显示个位 wela3=1; delay(2); wela3=0; delay(1); } void main() { uchar a; do { tmpchange(); for(a=10;a>0;a--) { display(tmp()); } if(temp>=310) //当温度超过31度,蜂鸣器便会报警。 { P1=0x00; beep=0; } else { beep=1; P1=0xff; } } while(1); } |
