i check the nand voltage 3.0v,voltage is ok
i checked the voltage near hdd 1v8,the voltage also OK..
HDD Reballed but same error
any solution please help作者: l2965687 时间: 2016-2-18 21:43
像是没有3V0,NAND 供电。。。错误,会白苹果大概作者: 最后的抉择 时间: 2016-2-18 22:06
How much is the flash reading the wrong code 作者: exe80901 时间: 2016-2-18 22:22
The CPU to U0301 i2c break line 作者: 怒海听涛 时间: 2016-2-19 09:02
提示: 该帖被管理员或版主屏蔽作者: l2965687 时间: 2016-2-19 22:02
cha 0301 zuobian de liangge dianrong dianya 作者: habeebkambrath 时间: 2016-2-23 16:04
i Checked the NAND Voltage 3.0v, Voltage is OK i checked the Voltage near hdd 1V8 ok... i reballed the hdd but same作者: 独木不成林 时间: 2016-2-23 16:08
tai diao le , wei yi kan de ming bai de yi ge hui fu .作者: 独木不成林 时间: 2016-2-23 16:24
不知道你看不看得明白,错误9不一定是硬盘的问题吖,你要说刷机进度条走到那里报错误9,刷机能亮白屏果吗?拆硬盘打值了没有作者: habeebkambrath 时间: 2016-2-26 14:46
i don't know ,what you say...作者: 断箭 时间: 2016-3-1 17:53
another PC and line,flash again.
