标题: 拯救者14 15 ISK 的BIOS [打印本页]
作者: willtauri 时间: 2016-1-17 16:10
本帖最后由 willtauri 于 2016-1-17 16:10 编辑 提供个BIOS,给需要的朋友们
拯救者14 15 ISK 的BIOS 0KCN23WW
具体更新说明在里面有文件
Updated Date 2015/11/09
Software name 0KCN23WW
Support models Rescuer-14ISK/15ISK
Operating Systems Microsoft Windows 10 64bit
Whatthispackagedoes:
BIOS, abbreviation of Basic Input / Output System, is integrated in ROM chip on main board, which contains the basic
Input/output program, system configuration information, system startup self-check and pre-setup programs.
BIOS provides most basic low-level hardware operations; it is the connection between software and hardware, and interfacing window of hardware and operating system.
Note: Make note of any settings you have changed in the BIOS Configuration Utility. These settings may have to be re-entered after updating the BIOS.
Attention: Do not power off or restart your computer during the BIOS flashing process, which will cause serious damage and improper functioning of your computer.
Print this file so that you can refer to it during the installation.
