标题: 【已修复】求INTEL NUC迷你机NUC5I5RYH BIOS [打印本页]
作者: 凤城 时间: 2016-1-13 08:22
需要编程器备份的文件,官网下载的就不用了
机器型号如下图:NUC5I5RYH
内存槽贴纸型号为:NUC5I5RYB
作者: 中博科技 时间: 2016-1-13 09:57
看不出,这么小,还是I5的处理器~官网的BIOS不是可以分离吗?版主都不会?
作者: 凤城 时间: 2016-1-15 09:01
没人有这个机器吗?
作者: 风神一笑 时间: 2016-1-15 09:37
凤叔 你这样是不是太诱惑会员了。。。500分啊。。
作者: wangfqlove 时间: 2016-1-15 10:18
找了一圈只有这个。me 是。10。xxxx
尽力了。。
Intel NUC5i5RYH NUC Kit BIOS 0247
New Fixes/Features: - Added BIOS options on the Secondary Power Settings page to enable or disable Wake from S3 via CIR and Wake from S4 and S5 via CIR.
- Added BIOS option on the Legacy Device Config page to select the CIR Remote Controller Type.
- Fixed issue where CIR remote fails in OpenELEC.
- Fixed issue where SMBIOS System Manufacturer and System Model do not appear correctly in MSINFO32 and other applications.
- Updated help string of USB charging port: Charging Only: USB Port will always provide extra power but cannot be used to transfer data with USB 2.0 device.
About This Release: - ME Firmware: 10.0.38.1000
- Integrated Graphics Option ROM: Build 1038_150303
- Integrated Graphics UEFI Driver: 5.5. 1032_150303
- LAN Option ROM: v1553 PXE 2.1 Build 092
- SATA RAID Option ROM: v13.5.0.1056
- Visual Bios: 2.2.16
Recovery BIOS Update [RY0247.BIO] - A .BIO file to be used for F7 BIOS Update method or a BIOS recovery process. In the unlikely event that a BIOS update is interrupted, it is possible the BIOS may be left in an unusable state. Use the recovery BIOS update to recover from this condition. It requires a USB flash device or CD
RYBDWI35.86A.0247.BI.zip
6.9 MB, 阅读权限: 100, 下载次数: 26, 下载积分: 下载分 -2 分, 下载 1 次
作者: 凤城 时间: 2016-1-15 17:05
官网的我已经下载过了,要提取分离的,因为没有原机BIOS,分离出来的BIOS刷上去现象一样,所以无法判断BIOS是好是坏。机子是更新BIOS时断电然后开机不显了
作者: 凤城 时间: 2016-1-15 17:06
要是有人有这机子,确认亮机的别说500,1000分都给
Powered by Discuz! X3.4 |
