查看: 2311|回复: 8
[显卡维修]
盈通9550 3D和QQ视频时死机
发表于 2009-1-21 10:49:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
128B 128M, 死机时有时会有些小花点。
因为对ATI的不熟,请坛子的兄弟帮忙看一下
R3MEMID version 1.13, (c) Copyright ATI Technologies Inc, 2004
Log file generation enabled to .\R3MEMID.LOG ...
Extended logging enabled ...
Reference data file (RDF) loading disabled ...
  [1] Fill
Failing bits in test [1] Fill
  errcount: 2
  MDA0: 34
  MDB0: 32 33 50 51 52 53 54 55 56 57 58 59 60 61 62 63
Failing bits in test [2] Data line toggle (GUI)
  errcount: 9000
  MDA0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  MDB0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
Failing bits in test [3] RW column (GUI)
  errcount: 36000
  MDA0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
  MDB0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
Failing bits in test [4] RW page (GUI)
  errcount: 36000
Failing bits in test [5] RW channel (GUI)
  errcount: 36000
Failing bits in test [6] Data mask
  errcount: 72000
Failing bits in test [7] Macro + Micro8x2 tiling read
  errcount: 8135
Failing bits in test [8] Macro + Micro4x4 tiling write
  errcount: 8794
Failing bits in test [9] Byte swap macro+micro8x2 read
  errcount: 72000
Failing bits in test [10] Byte swap macro+micro4x4 write
  errcount: 72000
TEST RESULT SUMMARY:
RV350/M10 (0x4153) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID G0VB001
  1024 x  768 - 16 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDA0 34 MDB0 32 33 50 51 52 53 54 55 ...
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID G0VB023
    failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 0 1 2 3 4 5 6 7 ...
[3  ] RW column (GUI)                                     : FAIL
    Error ID G0VB024
[4  ] RW page (GUI)                                       : FAIL
    Error ID G0VB025
[5  ] RW channel (GUI)                                    : FAIL
    Error ID G0VB028
[6  ] Data mask                                           : FAIL
    Error ID G0VB006
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
[7  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID G0VC006
[8  ] Macro + Micro4x4 tiling write                       : FAIL
    Error ID G0VC009
[9  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID G0VC018
[10 ] Byte swap macro+micro4x4 write                      : FAIL
    Error ID G0VC021
[11 ] Marco+Micro8x2 alignment write                      : PASS
[12 ] Macro+Micro4x4 alignment read                       : PASS
[13 ] Movblit, 4 align, T                                 : FAIL
    Error ID G0TR055
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.13 not found
[14 ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID G0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R051A.14 not found
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R052A.14 not found
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R053A.14 not found
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R055A.14 not found
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R061A.14 not found
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R062A.14 not found
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R063A.14 not found
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R065A.14 not found
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R071A.14 not found
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R072A.14 not found
     error : R073A.14 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R075A.14 not found
[15 ] Line slopes/dir/P/solid                             : FAIL
    Error ID G0TR010
     error : R051A.15 not found
     error : R052A.15 not found
     error : R053A.15 not found
     error : R055A.15 not found
     error : R061A.15 not found
     error : R062A.15 not found
     error : R063A.15 not found
     error : R065A.15 not found
     error : R071A.15 not found
     error : R072A.15 not found
     error : R073A.15 not found
     error : R075A.15 not found
Failure detected.
[ 本帖最后由 踪影 于 2009-1-21 12:10 编辑 ]
发表于 2009-1-21 10:56:08 | 只看该作者 �
开机花屏吗?你用什么软件测试的?怎么会全出错
发表于 2009-1-21 11:39:58 | 只看该作者 �
回复 2# 新诚达 的帖子
是论坛里下载的 9550 9600 x300 X550 测试软件,就一个EXE程序
运行后,是提示R3MEMID version 1.13
发表于 2009-1-21 11:40:27 | 只看该作者 �
发表于 2009-1-21 13:29:12 | 只看该作者 �
B区23坏掉显卡左边一组或者GPU内部局部已经损坏!
发表于 2009-1-22 22:12:54 | 只看该作者 �
先从A通道0--31处理.
这个不是叫A区的.是通道管理的与主板一样的管理.
发表于 2009-1-22 22:24:53 | 只看该作者 �
多谢潘总指导!
A卡和N卡都这么叫通道还是只有A卡才称为通道?
[ 本帖最后由 新诚达 于 2009-1-22 22:29 编辑 ]
发表于 2009-1-22 22:29:13 | 只看该作者 �
A又分为A0和A1
现在都用0的多,
发表于 2009-1-22 22:32:11 | 只看该作者 �
原帖由 jackiexp 于 2009-1-22 22:29 发表
A又分为A0和A1
现在都用0的多,
了解了!!多谢潘总!突然之间明白了以前的叫法是错的!
MDA0 MDB0
