标题: Toshiba L500 la-5322p HDD not detecting [打印本页]
作者: FAIZALAFRAD 时间: 2015-11-1 17:56
customer came this morning with Toshiba l500. Harddisk not detecting.
Checkedcd drive it's led lighten but try not ejecting suspect voltage drop.
Dissembledand checked voltage which is 3.3v and 5v
3.3vok but only 3v on +5vs rail.
Onq30 +5valw ok and 5v on gate but only 3v on source
Triedchange mosfet and got +5vs on source checked with hdd it was ok
作者: over91 时间: 2015-11-1 21:05
竟然还有外国友人,英语好的上吧
作者: 黑暗纪实 时间: 2015-11-1 22:20
看来论坛外国友人还是有 但是很少发帖
Powered by Discuz! X3.4 |
