The Agilent 66309D dual output mobile communications dc source provides two outputs for testing both the main battery power and the battery charger circuitry, allowing customers to test phones and chargers with the same equipment. This feature helps save on rack space (2 outputs in a half rack box) and eliminates the need for two separate power supplies. Excellent voltage transient response ensures maximum test-system throughput by minimizing device shutdowns due to significant voltage drops in the test wiring. The 66309D dc source provides all of the capabilities of the 66309B with the addition of a built in digital voltmeter.
The 66309D offers a new Agilent-developed feature that enables cellular-telephone manufacturers to detect permanently and intermittently open-sense wire connections automatically. Detection of open-sense wire connections allows users to prevent incorrect battery-charger calibration, incorrect test results and low-voltage phone shutdown due to a large transient voltage drop.
特性
Ideal for wireless/portable product test
Built in digital voltmeter
Dynamic pulse measurement
Fast transient response
Precision low current measurement
Low-output noise
High-speed programming
SCPI (Standard Commands for Programmable Instruments)
GPIB interface
Open sense detect
Visualize and characterize current and voltage waveforms (requires 14565A Device Characterization Software)
For complete details, click on the Product Overview link
额定输出
编程精度(25°C ±5°C)
纹波和噪声(20 Hz至20 MHz)
读回精度(25°C ±5°C)
安捷伦基础直流电源具备所需的各种基本特性,适用于预算紧张的用户。E3631A 80 W GPIB三路输出电源外形小巧,适用于工作台测
试。它的输出纹波和噪声较低,并内置测量和基本可编程功能;其过压保护功能可确保被测件的安全。这款灵巧、可靠的电源是为通
用应用设计的。它体积小巧,并可提供多路输出,将台式电源的便捷功能和系统电源的灵活特性完美地集于一身。
