标题: 电脑开机提示This computer system,#HWNVB2X-595B [打印本页] 作者: 旭华 时间: 2015-9-6 13:46 标题: 电脑开机提示This computer system,#HWNVB2X-595B dell pp38l电脑开机提示This computer system,#HWNVB2X-595B,is protected by a password authentication system.you cannot access the date on this computer without the correct password
please type in the system or administrator password and press<tnter>
进不了bios也进不了PE拆机换硬盘也没用F2和12按烂了就是进不去 作者: 淘气宝 时间: 2015-9-6 14:30
先刷一下BIOS吧!提示意思应是计算机系统错误。
