标题: 我的ST7200.7报错 [打印本页]
作者: 东方电脑维修    时间: 2008-12-27 18:44
标题: 我的ST7200.7报错
Interface task reset
1024k x 16 buffer detected
ALPINE - 1_Disk    M-21  11-25-03 18:53
Head Mask FFFF - Switch to full int.
              Spin Ready
8.01  09-28-04 15:05
(P)PATA Reset
Not Interface Age!
VALID Cert Disk Code Detected - Revision # .255
Cert Table loaded
No script first instruction.
No valid SeaDex script on disc.
Begin Test 31
                      Not Power Cycling
EP=0, TA=0, HiGain=0, OTRd=0, Early Rd=0, Splash=0, Reload=0, NPML=0, MRBias=0
Bst/Zap=0, SrvoThrsh=0, RunOut=0, MaxECC=0, ECC 2=0, ECC 1=0, ECC 0=0
Data=00, Write=32, ID=FF
作者: 我很想来看看    时间: 2008-12-27 19:07
已经自较到31了,视坏道情况和容量大小,快则几小时,慢者几天,等
