| 序号 | 打印机型号 | CPU(主CPU) | 从CPU | 门阵列电路 | 接口电路 | 字车电机控制与驱动 | 输纸电机控制与驱动 | 打印头控制与驱动 |
| 1 | EPSON LQ-100 | UPD7810HG | E05A71CA | SMA7029M | C4496×4 | 5DC03×6 | ||
| 2 | EPSON LQ-150K | UPD7810HG | ||||||
| 3 | EPSON LQ-510 | UPD7810HG | E05A0510 | SLA7020 | E05A02LA+晶体管 | |||
| 4 | EPSON LQ-1070+ | TMP90C041 | E05A86HG | E05A50BC | AD6712 | STA475 | SMA6501 | |
| 5 | EPSON LQ-800/1000 | UPD7810HG | SLA5040 | STK6982 | C3293×4 | C3705×24 | ||
| 6 | EPSON LQ-1500 | Z80A | 8041和8042 | 8255AC-5 | STK6982 | HA13007 | D1392×24 | |
| 7 | EPSON LQ-1600K | UPD7810HG | E05A10AA | M54610P | E05A09BA | E05A02LA D1978×24 | ||
| STK6722H | D560×4 | |||||||
| 8 | EPSON LQ-1600KⅡ | TMP90C041F | E05A50BC | STK6712 | PU1501 | STA475 | ||
| 9 | EPSON LQ-1800K | TMP90C041 | E0550BB | STK6022B | ||||
| 10 | EPSON LQ-1900K | TMP90C041F | E05A49BB | SLA7024M | PU1501 | UPA1428 | ||
| 11 | EPSON LQ-2000K | D78213GQ | E05A21AB | E05A24GH | E05A02LA+晶体管 | |||
| SLA7026M | PU4126 | |||||||
| 12 | EPSON LQ-2500K | UPD7810HG | E05020AA | SI7300A | C3293×4 | E05A02+晶体管 | ||
| 13 | EPSON RX-80 | UPD7810 | 2SC3293×4 | 2SC3293×4 | 2SC3293×9 | |||
| 14 | EPSON MX-80 | 8049/8039 | 8041/8741 | 8115 | 晶体三极管4只 | 晶体三极管4只 | 晶体三极管9只 | |
| 15 | EPSON FX-80/100/80+/100+ | 7810/7811 | 8042 | 门电路 | UPA79C+STK6982 | UPA79C+HA13007 | UPA79C+D1218×9 | |
| 16 | EPSON LX-800 | UPD7810HG | E5A03EA | C4169 | C4169 | D1647 | ||
| 17 | STAR AR-3200 | TMP90C041 | LC92015C-XBL3 | SLA4030 | STA4750A | TMP4020 | ||
| 18 | STAR AR-2463 | UPD7810 | UPD7810 | M54610P | PMM8714+D1308×4 | STA404A | UPD65006 STA403×6 | |
| 19 | STAR AR-3240 | TMP90C841 | D65006-015 | UPD65006CW-LC | D1725×4 | STA404A | STA405A×6 | |
| 20 | STAR AR-3240+ | TMP90C041 | H24W-1 | SMA5102 | SMA6511 | TMP4303 | ||
| 21 | STAR AR-4400 | D70108 | TMP90-C041 | HG62E66R96FSICH | SLA7026M | STA404A | LC920C0A-FIGA2SLA4060 | |
| 22 | STAR CR-3240 | TMP90C041 | D65012CW-ZB2 | LC92018B-ZB2 | SLA7026M | STA404A | MP4303 | |
| 23 | STAR CR-3200 | TMP90C041 | D65006-015 | MB624134U-XB | ENC1310 | STA404A | MP4106×6 | |
| 24 | STAR CR-3240II | TMP90C041 | ZBZGA1 | SLA7026M | ATA404A | SM4032 | ||
| 25 | STAR AR-2400 | TMP90C041 | LC92015C | STA401A | STA471A | STA471A | ||
| 26 | BROTHER M-1724 | M50734FP | M60005-0220FP | TH3L20 | TH3L20 | M505-021FP,M5248P×6 | ||
| 27 | BROTHR M-1324 | M60043-101EP | M50743FP | TH3L20 | 晶体管 | 晶体管 | ||
| 28 | BROTHER M-2724 | U3775-A | D78213GQ | D23C8001 ECZ-062 | D1789 | TH3L20 | D2388 | |
| 29 | BROTHER M-1924 | M50734FP | M60013-151PF | M60013-0147PF | SLA7020M | ENC1330-SPIF | MTA001M | |
| 30 | BROTHER M-2024 | HD6803 | HD6801 | 7414 7406等 | STA434A | STA401A | MS4567P×6 | |
| 31 | BROTHER AX-1900 | M50734FP | M6005-0217FP | M60013-0147PF | SLA7020M | ECN1330-SPIV | MTA001M | |
| 32 | NEC P6/P7 | UPD7810 | UPD7810 | 825 | 2SD1308×4 | 2SD1308×4 | 2SD1164×24 | |
| 33 | NEC9400 | UPD780C-1 | 8085 | 8255×2 | 2SD560×4 | 2SD560×4 | 2SD1164×24 | |
| 34 | NEC3300 | D78213GQ | 147156-002 | SLA4031 | SLA4031 | STA403A | ||
| 35 | NEC6300 | D70208GF-8 | 147-36-002,-P24CG6-03 | H67015CAC9 | ||||
| 36 | OKI8320 | 6051 | MSM61059 | MSM6990 | HA13412 | 2SD1472×4 | MHM2021×2 | |
| 37 | OKI 5320 | 6051 | MSM61059 | MSM6990 | HA13412 | 2SD1472×4 | MHM2021×2 | |
| 38 | OKI 5330C | M80C154V-1 | MSM6990 | HA13412 | MS4646AP | HA13412 | ||
| 39 | OKI MICR319 | U79H08 | MS6990 | HA13412 | HA13412 | MS4646P×6 | ||
| 40 | PANASONIC KX-P1211 | TMP90C854F | PSVIGP2404 | TMP4303 | 4AC21 | TMP4102 | ||
| 41 | PANASONIC KX-2828 | TMP90C854F | PSVIGP2404 | SLA77024M | TMP4012 | TMP4012 | ||
| 42 | FUJITSU DPK3600 | MB606508A | HD63009ECP | MB670535 | SLA7024 | SLA7024 | FT5764M | |
| 43 | FUJITSU DPK3600E | MB90706 | SLA7024 | UDN2916LR | SMA4032×6 | |||
| 44 | FUJITSU DPK8100/8200E | MB654510 | MB670535 | SMA4033 | SMA4033 | SMA4033×6 | ||
| 45 | FUJITSU DPK8300/8400E | HD63C09EP | MB654510 | MB670535 | SLA7024 | SMA4033 | SMA4033×6 | |
| 46 | 天津 ZH-1600K | TMP90C041 | CS70 IF60 | L6506 L298N | M5265P | HD60 MTA001×3 | ||
| 47 | TECOVP 1821 | D8085A | 8155HC | D768 | D768 | D1022 | ||
| 48 | PINOVIA 2440 | L1205637D | SCX6212 HKU | SCX6212 HKU | STK6712 AMK | TH3L10Z | MTA011 | |
| 49 | SAMSUNG SP-2421K | TMP9CP041 | STL7062-12V | |||||
| 50 | TOSHIBA 3070SL | T9770 | TMP4302 | TMP4501 | TMP4301 | |||
| 51 | AMT 325I | Z180 | IMI7160-6713 | TMP4303 | TMP4303 | |||
| 52 | CITIZEN 5240S | D70208GF-8 | P2503-300 | SI7300A | STA404A | FT5764M | ||
| 53 | EP-850 | 8031 | 8255 | TP42C | SN75436N | D1415 | ||
| 54 | 长城 2000 | GB24SFKH | M54610 | SLA7020M | STA412A | MTA001M | ||
| 55 | 紫金 3070 | 8085P | 8155P×2 | 2SD633×4 | TD62064P | TD62064P×6 | ||
