标题: 求B575E 充电IC 部分高清图片,有料板的可以帮测下其中一个电阻值大小,感谢 [打印本页]
作者: 金格    时间: 2015-5-10 21:58
作者: 不能再玩了    时间: 2015-5-10 22:32
你可以下载该芯片PDF 参考外围的范例,然后结合实际的基本没什么问题。
作者: 金格    时间: 2015-5-10 22:34
好像还有一个电阻也掉了,有高清图片,最好
作者: duncanspur    时间: 2015-5-11 05:53
BQ727 ---> TI   BQ24727
PIN 5 ACOK#   (LOW ENABLE)
PULL HIGH resistor    10K~100K
http://www.chinafix.com/forum.php?mod=viewthread&tid=815326
作者: duncanspur    时间: 2015-5-11 06:09
http://www.chinafix.com/thread-757652-1-1.html
BQ24707 datasheet
PIN 5   ACOK
AC adapter detect open drain output. It is pulled LOW to GND by an internal MOSFET when the voltage on the
ACDET pin is above 2.4V, voltage on the VCC pin is above UVLO and voltage on the VCC pin is 245mV above the
5 ACOK voltage on the SRN pin, indicating a valid adapter is present to start charge. If any one of the above conditions cannot
meet, it is pulled HIGH to the external pull-up supply rail by an external pull-up resistor. Connect a 10kΩ pull-up
resistor from the ACOK pin
to the pull-up supply rail.
bq24707.pdf (1.41 MB, 下载次数: 11)
